Old 10-29-2019, 05:52 PM #16
Justin.Geer81's Avatar
Justin.Geer81 Justin.Geer81 is offline
Justin.Geer81 is on a distinguished road
Originally Posted by 2016 4Runner SR5 View Post
285 is max on stock wheels, 295 is a very bad idea. You will need wheel spacers also which will lead to a BMC and other rubbing issues. Your main issue is stock Pro wheels are just not a good fit with bigger tires in general. Yeah I know people do it, doesn't make it right. Magic number is 17x8 with 4.5" back spacing and 0 offset.
Can you expand on that? Last sentence specifically I don’t quite understand
My main reason for even debating 285’s is that I’ve seen plenty of people around town with 285’s ... and if it helps ... the tires I will be getting are the nitto hybrid ridge grapplers ... they just look so sick ... I’d love to go bigger ... just not willing to drop the cash into it right now
It’s just winter ... and the nitto terra grapplers are about done ... at least for snow ... fine around town
Justin.Geer81 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 05:56 PM #17
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
I ran the Ridge Grapplers. Worst tire I have ever had. Driving in rain was like driving on ice. They look great, good in snow, quiet on road, horrible in rain. Anyway, the stock Pro wheels are 7" wide, not even really enough for a 285 The perfect wheel spec is 17x8 with 4.5" back spacing and 0 offset. With that combo, you will have the least possible chance of rubbing. Here's mine lifted 1.5" with 295/70/17 Ridge Grapplers on MX Pro wheels. All I did is a fender liner trim, no body mount chop, no rubbing.
Convince me to go to 285s-1-5-lift-295-jpg
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 06:20 PM #18
snowpeak snowpeak is offline
snowpeak has a spectacular aura about snowpeak has a spectacular aura about
Originally Posted by El Dusty View Post
I was pretty upset with my 285s in the fresh snow this morning. On slush and fresh snow the width really hurts your traction and tends to float you around...
Not sure if this matters in San Diego but with your name I figured Id throw it out there.
Thanks for the advice! I do get up in the mountains a lot, and motoring up to the ski lifts with friends will be important. This will be my daily driver so on-road performance is more important to me than off-road performance. I try to stay out of any off-road situation that's too extreme, so a larger tire may not be right for me. I've read good things about the Falkens, and with a slightly larger tire, the 275's should give me the improvement I'm looking for off-road as well.
2020 TRD ORP — MGM, KDSS, Billstein 6112 (2”) front, Billstein 5160 + 1” rear, C4 sliders, 275 WildPeaks, Rago rear window panels, GOBI stealth rack, HID low and LED high beams, SS3 sport yellow fogs, ARB single compressor, rock lights
snowpeak is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 06:21 PM #19
Originally Posted by Dillusion View Post
Well 285's ain't go big or go home but it is bigger.
You are asking a very opinionated question to some how convince your self you will be happy.
If you are worried about power personally bought the wrong vehicle to start.
I went with 285's because I didn't want to see the 275's on there and have them look to small. So I went to the biggest possible I knew could fit with minimal cutting. And of course some peoples opinion think 275 are more than big enough.
Best thing you can do it look at the million pics here and just go for it.
Thanks Dillusion, one of my concerns with stock tire size is looking too small after a lift. I figure that 275 cuts the difference between the two and it will look good both with stock suspension and a built suspension. Maybe I should stop thinking short term between no-lift and lift, and just wait until the lift to get the right tire.
Old 10-29-2019, 06:25 PM #20
Dang that looks good! Happy to see that size tire with minor trimming. This might be enough to convince me to go up in size!
Old 10-29-2019, 06:33 PM #21
kblaine123 kblaine123 is offline
kblaine123 is on a distinguished road
285's
I also have 285 Toyo AT's....(2018 SR5 premium) no BMC, no rub, no fender cutting, no re-gearing. Slight lift in rear with Bilstein 5100 up front.
I would add....if you go 285's, stay cognizant to wheel weight. I have some relatively lighter Fuel Wheels I'm running which work great.....I think the ideal wheel is what Chris has which is the FN FX Pro, they are light and great looking.
kblaine123 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 07:18 PM #22
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
I have 285/70/17s and its niiiice! I do get a little rubbing in full lock in reverse, but just don't do that ever!!!
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 08:39 PM #23
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
I still think 285 look too small personally but I'm not willing to cut more so I have to live with it.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 11:30 PM #24
@jrfordlandia's Avatar
@jrfordlandia @jrfordlandia is offline
Real Name: Jason Ford (not related to Henry or Harrison)
@jrfordlandia will become famous soon enough
Originally Posted by Jarheadoo7 View Post
He’s right. 285 is the gateway drug you waste money on. 295 is where you’ll get the most beef for your buck and get kicked in the gas enough to prevent you from entering the 300’s.
At what size does regearing become an issue? I seem to recall 285s push the limits before needing different gears of power loss, mileage, and speedo are concerns. If your looking at 295s or 300s, maybe none of that matters. 🤣
2018 4Runner 4x4 SR5P, Super White w/Third Row, 285-KO2's, SCS Ray10’s, Dobinson 302/505 springs with 700/705 gas shocks, Tandem Sliders, TRD Skid, Cold Air Intake
2015 4Runner 4x2 SR5 Premium, 5100’s, KO2's, Super White (sold)
@jrfordlandia is offline   Reply With QuoteReply With Quote
Old 10-30-2019, 07:38 PM #25
This post goes into detail on re-gearing. Changing Tire Size or Wheels? Read this first! and states anything larger than 33" will need re-gearing. At 32", the differences will be negligible, making the 275/70/17 a better choice IMO. I've pushed the stock wheels off-road and found their limit. Perhaps I'll do the same with the 32's and then make a decision to upgrade.
Old 10-30-2019, 11:43 PM #26
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
If you run 285 in P rate you'll save more weight.
Toyo open country ATs 48# pounds are not as tall as the newly released Firestone Destinations AT2 at 42# pounds with an impressive 13/32. The destinations has much better rain performance and more sipping and I believe it was designed for snow as well. OCs were louder and sat much wider.
I gained an extra 1 mpg by going from the Toyo OC to the FS destinations if that matters but the mpg gain and quicker acceleration was back.
I ran C rated 275 Wildpeaks for a few weeks but I felt the weight, it was horrible entering freeways but they did ride very soft and comfortable. I went on to swap to 285 P rated Wildpeaks for mpg recovery and they were great but I had to do a road hazard after I drove home with a bent steering knuckle from the off-road park 4 hours away from home. Then came the toyos OCs and now Fs Destinations AT2 which I'll have the opportunity to try at the offroad park soon.
As stated before lighter wheels would help greatly, some FN or SCS wheels at 22# would be ideal.
Do what you feel what is right for you and your budget, it'll all change up again sooner or later. Go make some good friends at discount tire and firestone, bring them some beer, that's how I was able to play dressing room with all my tire options and not spend much at all for their services and favors. Good luck!
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 11-01-2019, 04:30 PM #27
That looks SICK man! Do the TRD center caps fit on those wheels?
Old 11-02-2019, 12:28 PM #28
Real Name: Chris
Real Name: Chris
Thank you. No they do not. I ordered matte black TRD stickers to put on the caps that these wheels come with just for a little contrast. These wheels are designed after the TRD wheel but they are an improvement over the OEM specs.
Old 11-05-2019, 01:51 AM #29
Alright I went with 32s. 275/70/17 Falken Wildpeak AT3W in C load. It checked all the boxes for me. C is the right balance for me between off-road and on-road durability and comfort. Great snow rating, good in rain and sand, good reviews, consumer reports recommended, and at the right price.
Before
After
Old 11-05-2019, 07:22 PM #30
hwnrunner's Avatar
hwnrunner hwnrunner is offline
hwnrunner will become famous soon enough hwnrunner will become famous soon enough
hwnrunner's Avatar
Talking
Looks the same! Sorry just kidding.
Good choice!
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
hwnrunner is offline   Reply With QuoteReply With Quote
lift , load , stock , tires , wait
HTML code is Off
Convince me to buy a 4th gen instead of a 3rd gen OkiSurf1996 4th Gen T4Rs 12 08-11-2015 04:24 PM
Help me convince my wife we need a 4th gen! Xetabur 4th Gen T4Rs 25 05-20-2015 10:09 PM
285s or 265s? Do the 285s look that much better? 4RunnerTrail 5th gen T4Rs 23 11-16-2011 12:42 PM
Trying to convince a friend... Millerad1651 3rd gen T4Rs 3 11-01-2011 05:36 PM
Convince me PoPo 4th Gen T4Rs 22 01-17-2005 10:14 AM
