10-28-2019, 09:11 PM
Convince me to go to 285s
I have a stock 2020 TRD Off-Road Premium and I’m about to pull the trigger on a set of Falken Wildpeak AT3 in 275/70/17 load range C. My previous rig had KO2s in E load and the cool factor wore off pretty fast around 20,000 miles with some serious vibration and road noise. Harsh ride the whole time. Hopefully I’ll be happier with C load LT tires.
I’ve debated back and forth with myself and buddies about whether or not to buy tires now while I can get a great deal (around $260 off a set of 4) or wait until I have a lift installed and go big or go home with 285’s.
275/70/17 Pros/Cons
- No mods required to prevent rubbing
- split the difference between stock and 285 means the best of both worlds?
- closer to stock gearing and spedo more accurate
- about 2 lbs lighter than the 285 (57 lbs vs 59)
- able find it in load range C
285/70/17 Pros/Cons
- need to wait until the lift to install tires
- mods required to prevent rubbing
- more capable off-road
- better looking larger tire
- more options available than the 275 size
I’m looking at a mild lift, Bilstein 5100s all the way around with 1” taller springs in the back.
Should I wait and get 285s, or will I be happy with the lift and 275s? My off-road preference is some tough but mostly easier trails and overlanding.
2020 TRD ORP — MGM, KDSS, Billstein 6112 (2”) front, Billstein 5160 + 1” rear, C4 sliders, 275 WildPeaks, Rago rear window panels, GOBI stealth rack, HID low and LED high beams, SS3 sport yellow fogs, ARB single compressor, rock lights
10-28-2019, 09:16 PM
Ok, I'll help you. Why not go all the way up to 295 if going up to 285, same trimming and BMC required. Sounds like you want the bigger tire.
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
10-28-2019, 09:37 PM
He’s right. 285 is the gateway drug you waste money on. 295 is where you’ll get the most beef for your buck and get kicked in the gas enough to prevent you from entering the 300’s.
10-28-2019, 10:03 PM
Gateway drug is what I’m worried about with the 275’s haha. Thanks for the advice
10-28-2019, 10:05 PM
That does not help, that’s yet another good option to consider!
10-28-2019, 10:14 PM
Real Name: Chris
Real Name: Chris
285/70/17 on stock suspension with nothing more than a fender liner mod. No BMC and no rubbing. Street driving only of course. I am now on a 295 but that's already been covered.
10-28-2019, 11:00 PM
If someone else needs you to convince you to do something its the wrong decision.
2018 TRD OFF ROAD
My Build
10-29-2019, 05:03 AM
I like the 275/70 tires. Mine are E-load KO2s. They were a bit rough on the stock suspension and wheels at first, but I switched to lighter wheels (21 lb FN Six shooters) which helps cycle the suspension closer to the stock rate. I also got Pro takeoff shocks, which smoothed it out even more.
Speedo is dead on, checked with GPS (speedo with stock tires reads fast).
Personally, I don't think the extra headache for getting all of the required clearance is worth it. You're only gaining a quarter of an inch of ground clearance (32.2 vs 32.7 diameter) and less than a half inch of width. And width doesn't really do that much for you besides look cool. Lots of guys run 255/80 "pizza cutter" tires which are 33.1" diameter and require much less work to clear. Most don't need a body mount chop even for full stuff/lock.
I think 275/70R17 is the best bang for the buck, as long as you like the tire brands/models.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
10-29-2019, 10:49 AM
It’s just a title to capture your attention. Thanks to everyone else providing valid opinions. This is helpful
10-29-2019, 11:18 AM
Originally Posted by snowpeak
285/70/17 Pros/Cons
I was pretty upset with my 285s in the fresh snow this morning. On slush and fresh snow the width really hurts your traction and tends to float you around...
Not sure if this matters in San Diego but with your name I figured Id throw it out there.
10-29-2019, 11:30 AM
Going 285, 295, etc........don’t you lose a ton of power on the road? Good luck using cruise control or mountain passes! Heavy as hell too...all unsprung weight. At what point do you have to re-gear?
10-29-2019, 12:14 PM
Well 285's ain't go big or go home but it is bigger.
You are asking a very opinionated question to some how convince your self you will be happy.
If you are worried about power personally bought the wrong vehicle to start.
I went with 285's because I didn't want to see the 275's on there and have them look to small. So I went to the biggest possible I knew could fit with minimal cutting. And of course some peoples opinion think 275 are more than big enough.
Best thing you can do it look at the million pics here and just go for it.
2018 TRD OFF ROAD
My Build
10-29-2019, 12:32 PM
So if I have a revtek leveled 2018 TRD off road premium ... lifted 3” w/dif drop in the front ... 2” rear
Will the 285/70 17 be fine ... what about the 295’s? (Which I hadn’t considered until this post ... thanks ... lol)
Also on TRD stock black wheels
10-29-2019, 05:05 PM
Real Name: Chris
Real Name: Chris
285 is max on stock wheels, 295 is a very bad idea. You will need wheel spacers also which will lead to a BMC and other rubbing issues. Your main issue is stock Pro wheels are just not a good fit with bigger tires in general. Yeah I know people do it, doesn't make it right. Magic number is 17x8 with 4.5" back spacing and 0 offset.
10-29-2019, 05:11 PM
4Runner Tire Guide:
285 is the largest easy size to fit with very minor trimming.
315/35's takes some money and trimming.
295's combine the worst of both worlds.
You can move to 37's only once you think your 35's "look" small.
HTML code is Off
