Old 10-28-2019, 09:11 PM #1
snowpeak snowpeak is offline
snowpeak has a spectacular aura about snowpeak has a spectacular aura about
Convince me to go to 285s
I have a stock 2020 TRD Off-Road Premium and I’m about to pull the trigger on a set of Falken Wildpeak AT3 in 275/70/17 load range C. My previous rig had KO2s in E load and the cool factor wore off pretty fast around 20,000 miles with some serious vibration and road noise. Harsh ride the whole time. Hopefully I’ll be happier with C load LT tires.
I’ve debated back and forth with myself and buddies about whether or not to buy tires now while I can get a great deal (around $260 off a set of 4) or wait until I have a lift installed and go big or go home with 285’s.
275/70/17 Pros/Cons
- No mods required to prevent rubbing
- split the difference between stock and 285 means the best of both worlds?
- closer to stock gearing and spedo more accurate
- about 2 lbs lighter than the 285 (57 lbs vs 59)
- able find it in load range C
285/70/17 Pros/Cons
- need to wait until the lift to install tires
- mods required to prevent rubbing
- more capable off-road
- better looking larger tire
- more options available than the 275 size
I’m looking at a mild lift, Bilstein 5100s all the way around with 1” taller springs in the back.
Should I wait and get 285s, or will I be happy with the lift and 275s? My off-road preference is some tough but mostly easier trails and overlanding.
2020 TRD ORP — MGM, KDSS, Billstein 6112 (2”) front, Billstein 5160 + 1” rear, C4 sliders, 275 WildPeaks, Rago rear window panels, GOBI stealth rack, HID low and LED high beams, SS3 sport yellow fogs, ARB single compressor, rock lights
snowpeak is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 09:16 PM #2
hwnrunner's Avatar
hwnrunner hwnrunner is offline
hwnrunner will become famous soon enough hwnrunner will become famous soon enough
hwnrunner's Avatar
Ok, I'll help you. Why not go all the way up to 295 if going up to 285, same trimming and BMC required. Sounds like you want the bigger tire.
2019 SR5 Premium 2WD - TRD PRO Front Struts & Coils w/ Toytec 1" Perch Spacer / Dobinson's C59-505 Rear Springs / ICON VS 2.0 Rear Shocks / TRD PRO Grill & Valences/ TRD CAI /URD MAF Calibrator / TRD PRO Wheels / BFG KO2 275 70 17
hwnrunner is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 09:37 PM #3
Jarheadoo7's Avatar
Jarheadoo7 Jarheadoo7 is offline
Jarheadoo7 will become famous soon enough
Jarheadoo7's Avatar
He’s right. 285 is the gateway drug you waste money on. 295 is where you’ll get the most beef for your buck and get kicked in the gas enough to prevent you from entering the 300’s.
Jarheadoo7 is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 10:03 PM #4
Gateway drug is what I’m worried about with the 275’s haha. Thanks for the advice
Old 10-28-2019, 10:05 PM #5
That does not help, that’s yet another good option to consider! Convince me to go to 285s
Old 10-28-2019, 10:14 PM #6
2016 4Runner SR5's Avatar
2016 4Runner SR5 2016 4Runner SR5 is offline
Real Name: Chris
2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold 2016 4Runner SR5 is a splendid one to behold
Real Name: Chris
285/70/17 on stock suspension with nothing more than a fender liner mod. No BMC and no rubbing. Street driving only of course. I am now on a 295 but that's already been covered.
Convince me to go to 285s-285-stock-jpg  Convince me to go to 285s-295-mickey-thompson-jpg
2016 4Runner SR5 is offline   Reply With QuoteReply With Quote
Old 10-28-2019, 11:00 PM #7
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
If someone else needs you to convince you to do something its the wrong decision.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 05:03 AM #8
mynameistory's Avatar
mynameistory mynameistory is offline
mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold mynameistory is a splendid one to behold
I like the 275/70 tires. Mine are E-load KO2s. They were a bit rough on the stock suspension and wheels at first, but I switched to lighter wheels (21 lb FN Six shooters) which helps cycle the suspension closer to the stock rate. I also got Pro takeoff shocks, which smoothed it out even more.
Speedo is dead on, checked with GPS (speedo with stock tires reads fast).
Personally, I don't think the extra headache for getting all of the required clearance is worth it. You're only gaining a quarter of an inch of ground clearance (32.2 vs 32.7 diameter) and less than a half inch of width. And width doesn't really do that much for you besides look cool. Lots of guys run 255/80 "pizza cutter" tires which are 33.1" diameter and require much less work to clear. Most don't need a body mount chop even for full stuff/lock.
I think 275/70R17 is the best bang for the buck, as long as you like the tire brands/models.
-Tory
- 2016 4Runner - WeatherTech Floor Liners - Key Fob Window Roll-down Mod - 35 PSI Tire Pressure - Gum Holder Delete - iOttie Phone Holder - RainX Windshield Mod - Stock Windshield Wipers (for now) - Radio Stations are 105.9, 106.7, 95.5, and 93.1 - Chrome Exhaust Tip - Really want a Gobi Ladder but I guess I'll just stand on the Tire because it's free and does the same thing - Some Old Coleman Ice Chest - A Gas Can I Found -
mynameistory is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 10:49 AM #9
It’s just a title to capture your attention. Thanks to everyone else providing valid opinions. This is helpful
Old 10-29-2019, 11:18 AM #10
El Dusty's Avatar
El Dusty El Dusty is online now
El Dusty has a spectacular aura about El Dusty has a spectacular aura about El Dusty has a spectacular aura about
El Dusty's Avatar
Originally Posted by snowpeak View Post
285/70/17 Pros/Cons
I was pretty upset with my 285s in the fresh snow this morning. On slush and fresh snow the width really hurts your traction and tends to float you around...
Not sure if this matters in San Diego but with your name I figured Id throw it out there.
El Dusty is online now   Reply With QuoteReply With Quote
Old 10-29-2019, 11:30 AM #11
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Going 285, 295, etc........don’t you lose a ton of power on the road? Good luck using cruise control or mountain passes! Heavy as hell too...all unsprung weight. At what point do you have to re-gear?
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 12:14 PM #12
Well 285's ain't go big or go home but it is bigger.
You are asking a very opinionated question to some how convince your self you will be happy.
If you are worried about power personally bought the wrong vehicle to start.
I went with 285's because I didn't want to see the 275's on there and have them look to small. So I went to the biggest possible I knew could fit with minimal cutting. And of course some peoples opinion think 275 are more than big enough.
Best thing you can do it look at the million pics here and just go for it.
2018 TRD OFF ROAD
My Build
Old 10-29-2019, 12:32 PM #13
Justin.Geer81's Avatar
Justin.Geer81 Justin.Geer81 is offline
Justin.Geer81 is on a distinguished road
So if I have a revtek leveled 2018 TRD off road premium ... lifted 3” w/dif drop in the front ... 2” rear
Will the 285/70 17 be fine ... what about the 295’s? (Which I hadn’t considered until this post ... thanks ... lol)
Also on TRD stock black wheels
Justin.Geer81 is offline   Reply With QuoteReply With Quote
Old 10-29-2019, 05:05 PM #14
Real Name: Chris
Real Name: Chris
285 is max on stock wheels, 295 is a very bad idea. You will need wheel spacers also which will lead to a BMC and other rubbing issues. Your main issue is stock Pro wheels are just not a good fit with bigger tires in general. Yeah I know people do it, doesn't make it right. Magic number is 17x8 with 4.5" back spacing and 0 offset.
Old 10-29-2019, 05:11 PM #15
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
4Runner Tire Guide:
285 is the largest easy size to fit with very minor trimming.
315/35's takes some money and trimming.
295's combine the worst of both worlds.
You can move to 37's only once you think your 35's "look" small.
Inv4drZm is offline   Reply With QuoteReply With Quote
lift , load , stock , tires , wait
HTML code is Off
Convince me to buy a 4th gen instead of a 3rd gen OkiSurf1996 4th Gen T4Rs 12 08-11-2015 04:24 PM
Help me convince my wife we need a 4th gen! Xetabur 4th Gen T4Rs 25 05-20-2015 10:09 PM
285s or 265s? Do the 285s look that much better? 4RunnerTrail 5th gen T4Rs 23 11-16-2011 12:42 PM
Trying to convince a friend... Millerad1651 3rd gen T4Rs 3 11-01-2011 05:36 PM
Convince me PoPo 4th Gen T4Rs 22 01-17-2005 10:14 AM
