Old 11-18-2019, 09:55 AM #1
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
Suspension question
Ultimately I'll end up with armored bumper and winch up front, bumper and spare carrier in back. Don't currently have them though. Getting ready to throw on OME lift. Do I put the heavier rated springs on now? Mid weight springs now and deal with swapping springs when I add the bumpers? I just don't know how uncomfortable the ride will be with out thi e bumpers to weigh down the springs...or if my wheels won't be able to be aligned properly even.
Thanks for in put.
G_Raw is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 10:32 AM #2
Narat_524 Narat_524 is offline
Narat_524 will become famous soon enough
How long?
The question is how long will you be driving until you get all the "stuff" put on that you plan to put on it?
Given my own recent experience with exactly this issue, the front springs (550 lbs, vs std 500) are fine, but the rears are 3" +400lbs, and they're stiff without any weight - to the extent that I put 250lbs of batteries and metal over the rear axle so I could drive it daily without losing a kidney.
I've driven a 3/4 ton diesel truck for the last 17 years, so I'm not unaccustomed to a rough ride, and before I put all the armor and camping do-dads in it, it was just not the ride I wanted out of my 4Runner.
If I had to do it again, I would have put the softer springs in the rear and swapped them out once I got everything else put on. The first time you swap springs, it sucks. Once you know the tricks, second time around was a breeze.
2019 TRD ORP, Milestar Patagonia LT295/70R17, Method Trail 701 wheels, King suspension 600 sprgs, Dobinson C59-677V +400 rr sprgs, ECGS 4.56 grs, Frt E-Locker, Coastal Offroad Alu dual swing rear bmpr, CBI Alu frt bumper, SmittyBilt X20 10K Synth, Flatlink E, RCI full steel skids and sliders, DuroBumps, MetalTech RR LCA, Dual 31M/34M Northstar Batts, Blue Sea ML-ACR, LFD Offroad Bat tray, Schrockworks air pump relo brkt, ARB twin comp, Gibson exh, Infinity Component dsh and dr spkrs, Hertz HCX 165 hatch spkrs, 2x Kicker KEY 180.4 DSP amps, Kenwood TM-V71, Cobra 75 WX ST, Midland MXT275, ArcLight LEDs, XenonDepot HID low, LED High, Diode Dynamics Turn-as-Tail, Switchbacks, CaliRaised Ditch light brackets, Rigid SS Ditch lights, Stock OR wheels with 285/70R17 E GY DuraTracs, Custom drawer/sleep platform, Dometic CFX50, More lights and antennas than I can name, beer
Narat_524 is offline   Reply With QuoteReply With Quote
Old 11-18-2019, 10:18 PM #3
G_Raw's Avatar
G_Raw's Avatar
Plan is lift, tires, pan hard correction, sway links extended. All at once.
Regear and lsd
Bumper plus winch
Bumper plus spare
In that order.
But since both bumper set ups are some money and the lifting properly takes some money...There will be time between this all...months perhaps. So if I lift now...itd be till after the holidays for the front bumper, then till mid spring for the rear...
I've dealt with swapping springs and own spring compresses so not worried about that...It's just extra time, work, and money is all.
Alternatively I guess I could try to be patient and stack parts over the course of 6 months then transform the whole ride over a week.
bumper , bumpers , put , ride , springs
HTML code is Off
FJ Suspension Question Jeffrey_VB 4th Gen T4Rs 3 06-11-2014 09:36 PM
Suspension question Tigerfan86 4th Gen T4Rs 0 05-28-2014 07:34 PM
Question about FJ suspension swap (not a common question) cacarbuff 4th Gen T4Rs 2 02-18-2014 10:37 PM
I know.... I'm sorry.... But I have a suspension question MeBe4running 5th gen T4Rs 30 12-19-2012 12:26 AM
suspension question? pdx-97runner Engines / Suspension / Wheels / Tires / Audio / Accessories 6 01-15-2004 02:18 AM
