Old 12-07-2019, 10:37 PM #16
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R is a glorious beacon of light MAST4R is a glorious beacon of light MAST4R is a glorious beacon of light MAST4R is a glorious beacon of light MAST4R is a glorious beacon of light MAST4R is a glorious beacon of light
MAST4R's Avatar
Originally Posted by WRENCHHEAD View Post
what load rating/ ply count are the tires?
Yup, if they are E load that's another story.
SL in stock size should balance perfectly and if they don't, then maybe complain and ask for replacement.
I cannot tell they are AT tires on pavement and I have been driving on AT tires for 10 years on one vehicle and street tires on another.
In fact, the performance tires on our Subaru are less civilized than these AT tires in terms of comfort.
Old 12-07-2019, 10:41 PM #17
Syr4RinNC is on a distinguished road
Originally Posted by jgmx893 View Post
So took the psi up to 38 from where it was around 35-36 today and still didn't notice a difference. So between the 30-38psi which I have tested it seems like none of it really matters for these tires in terms of noise.
If anything, they're only (slightly) quieter above like 35 psi or so. Maybe I'm just expecting too much from an aggressive A/T tire haha.
It's just that these things are a good amount louder than the Cooper AT3's I was running before so I was kinda shocked.
Thanks for the feedback. Yea for me Im not noticing a lot of noise. Im just feeling a lot of vibration where my feet are driving
Old 12-08-2019, 07:22 PM #18
So I took mine back in to get balanced. Apparently the balancing wasnt the issue so to speak.
They found that one of my calipers was leaking brake fluid and was likely frozen with a warped rotor.
Due to the leaking brake fluid, the weights on one of the wheels came off
If I had the time and didnt need it tomorrow morning, I've done it myself, but $900 later, everything is running fairly smoothly for me
Old 12-13-2019, 10:58 AM #19
MicMul MicMul is offline
Real Name: Michael
MicMul is on a distinguished road
MY GARAGE
Real Name: Michael
MY GARAGE
OP,
I don't have experience with Falkens, but I do have Nitto Ridge Grapplers which do sound like really quiet MTs when on smooth ashphalt roads. Like you, I'm able to hear the tread blocks hitting the road surface when coming to a stop. Have you run your hand over the tread to feel for flat spots/irregular wear?
MicMul is offline   Reply With QuoteReply With Quote
Old 12-13-2019, 11:20 AM #20
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN is on a distinguished road
TodiN's Avatar
Real Name: Todi
I have AT3/W in E 285/70-17 and they are quieter that the POS OEM tires I had for two years... or is just me getting old
2018 TRD OR
- SSO Full Rack; FJ TRD Pro Kit with: Front - 1.25" Lift Poly Front Coil Preload Spacer Kit (DAY TA3273), Rear - Eibach E30-82-071-01-02; M.O.R.E. aluminum full set skid plates; RCI front filler skid plate; removed Spidertrax wheel spacers; Pedal Commander; ARB diff breather; on-board Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Whildpeak AT3W LT285/70-17 E
TodiN is offline   Reply With QuoteReply With Quote
loud , louder , noise , road , rotating
HTML code is Off
New Falken Wildpeak M/T Konkordmusk 3rd gen T4Rs 16 01-06-2020 01:06 PM
WTT Falken Wildpeak 265/75/16 for your 285ís Bmthompson10 Want to Buy/Trade 1 11-07-2019 03:28 AM
VA - Falken Wildpeak A/T3W - 265/70/17 (4) shyuperman For Sale: Suspension/Wheels/Tires 2 10-09-2018 09:38 AM
Falken wildpeak at3 Rudeboy706 3rd gen T4Rs 6 05-30-2017 06:49 PM
Copyright © 2019
