Old 12-04-2019, 10:24 PM #1
jackacc's Avatar
jackacc jackacc is offline
jackacc is on a distinguished road
jackacc's Avatar
What parts do I need to assemble front shocks and lift springs before install?
I'm going to install lift springs and new shocks on my 2019 OR and want to assemble everything before I do the install.
What parts would I need to buy to allow me to assemble the fronts completely so I can just drop the stock set out and put the new set in?
2019 4Runner TRD Off Road
jackacc is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 01:00 PM #2
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Some people use the home spring compressors but I just take it somewhere to get put on.
https://www.amazon.com/OrionMotorTec...xpY2s9dHJ1ZQ==
I'd rather not have the spring flying at me.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 01:43 PM #3
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
rent compressors
My local O'Reilly's auto parts rented the spring compressors to me for free. I paid $50 to get them and if you return within 48 hrs, they give you 100% money back. I put some spacers on my front end this past week, works great.
Jpilot is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 02:22 PM #4
jackacc's Avatar
jackacc's Avatar
Thanks you guys, at first I was going to hire a shop but I think I can get it done myself. I am definitely going to rent a spring compressor to assemble the fronts but I should have been more specific.
I wanted to know about the parts like top hats, washers, nuts, bushings etc. that are usually removed from the stock setup. I want to build the shock/spring setup before I remove the original setup from the truck so I can easily swap them in. My 4R is a lease so I wanted to be able to easily swap it back to stock if I don't wind up buying it at the end of the term and then sell the lift fully assembled.
I was hoping someone who has completed the installation could let me know exactly what parts are moved over from the stock setup so I can price out the parts to see if it is worth it.
Old 12-06-2019, 07:59 PM #5
I think your stuff should come with new parts if stock couldn't be reused.
Unless you literally only bought the springs and struts.
2018 TRD OFF ROAD
My Build
Old 12-06-2019, 09:30 PM #6
jackacc's Avatar
jackacc's Avatar
Yeah I just bought springs and shocks, haven't received them yet. Some of the stock parts are reused but I wanted to order those so I can assemble ahead of time.
Old 12-06-2019, 09:39 PM #7
Guess where did you buy it from? Piece mail it?
2018 TRD OFF ROAD
My Build
Old 12-12-2019, 11:41 AM #8
MicMul MicMul is offline
Real Name: Michael
MicMul is on a distinguished road
Real Name: Michael
It sounds like you just need the upper shock mounts to complete the front assemblies.
MicMul is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 10:11 AM #9
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Yea, you'll need to get the top strut mounts - kyb makes them and they're pretty cheap.
I wouldn't bother assembling them beforehand, I think it's actually way easier (and safer) to use the weight of the vehicle to compress the coil and get everything bolted up.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 10:31 AM #10
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN will become famous soon enough
TodiN's Avatar
Real Name: Todi
Spring compressor method if not done properly can be dangerous. I’ve used the no spring compressor method as mentioned before, see this video: YouTube . Make sure you torque everything per specs.
When/if you return the truck, you can then remove all assembly and return the truck to original state.
2018 TRD OR
- SSO Full Rack; Ironman 4x4 Stage 3 Foam Cell Pro: Constant Load – front, Performance Load – rear; M.O.R.E. aluminum full set skid plates; Artec aluminum gas tank skid; RCI front filler skid plate; HetfyFab Low-Profile Banshee Bumper; ReszFab flat sliders; Smittybilt 98695 XRC 9.5K GEN3 Winch; Pedal Commander; ARB diff breather; Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Wildpeak AT3W LT285/70-17 E;
TodiN is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 05:54 PM #11
jackacc's Avatar
jackacc's Avatar
Thank you for the info guys, the no spring compressor method looks much easier. I think I will go that route.
The rears shouldn't be too different from all the Jeeps I've lifted in the past.
assemble , install , parts , set , springs
HTML code is Off
FS: 5th Gen (2016 Trail) Front Coilover Shocks & Rear Shocks/Springs $175, West LA rgoodman00 For Sale: Suspension/Wheels/Tires 3 01-28-2016 03:22 PM
: 3rd G FS99 Tall Springs F+R and Front Shocks, 4R Wheels and tires, 97 springs SoCal mydogsmonkey For Sale: Suspension/Wheels/Tires 1 07-11-2014 10:36 AM
Getting Rid of OME Shocks, Springs, Front lift 5th4runner 3rd gen T4Rs 5 04-08-2014 02:00 PM
'99 front springs/shocks w/spacer & rear springs Full_Throttle For Sale: Suspension/Wheels/Tires 10 09-18-2012 11:57 PM
FJRunner lift installed (FJ springs/shocks and front spacer) gaberelli 4th Gen T4Rs 13 11-07-2009 10:35 PM
