Old 12-04-2019, 10:24 PM #1
jackacc's Avatar
jackacc jackacc is offline
jackacc is on a distinguished road
jackacc's Avatar
What parts do I need to assemble front shocks and lift springs before install?
I'm going to install lift springs and new shocks on my 2019 OR and want to assemble everything before I do the install.
What parts would I need to buy to allow me to assemble the fronts completely so I can just drop the stock set out and put the new set in?
2019 4Runner TRD Off Road
jackacc is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 01:00 PM #2
Dillusion Dillusion is offline
Dillusion is just really nice Dillusion is just really nice Dillusion is just really nice Dillusion is just really nice
Some people use the home spring compressors but I just take it somewhere to get put on.
https://www.amazon.com/OrionMotorTec...xpY2s9dHJ1ZQ==
I'd rather not have the spring flying at me.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 01:43 PM #3
Jpilot Jpilot is offline
Jpilot is on a distinguished road
rent compressors
My local O'Reilly's auto parts rented the spring compressors to me for free. I paid $50 to get them and if you return within 48 hrs, they give you 100% money back. I put some spacers on my front end this past week, works great.
Jpilot is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 02:22 PM #4
jackacc's Avatar
jackacc's Avatar
Thanks you guys, at first I was going to hire a shop but I think I can get it done myself. I am definitely going to rent a spring compressor to assemble the fronts but I should have been more specific.
I wanted to know about the parts like top hats, washers, nuts, bushings etc. that are usually removed from the stock setup. I want to build the shock/spring setup before I remove the original setup from the truck so I can easily swap them in. My 4R is a lease so I wanted to be able to easily swap it back to stock if I don't wind up buying it at the end of the term and then sell the lift fully assembled.
I was hoping someone who has completed the installation could let me know exactly what parts are moved over from the stock setup so I can price out the parts to see if it is worth it.
Old 12-06-2019, 07:59 PM #5
I think your stuff should come with new parts if stock couldn't be reused.
Unless you literally only bought the springs and struts.
2018 TRD OFF ROAD
My Build
Old 12-06-2019, 09:30 PM #6
jackacc's Avatar
jackacc's Avatar
Yeah I just bought springs and shocks, haven't received them yet. Some of the stock parts are reused but I wanted to order those so I can assemble ahead of time.
Old 12-06-2019, 09:39 PM #7
Guess where did you buy it from? Piece mail it?
2018 TRD OFF ROAD
My Build
Old 12-12-2019, 11:41 AM #8
MicMul MicMul is offline
Real Name: Michael
MicMul is on a distinguished road
MY GARAGE
Real Name: Michael
MY GARAGE
It sounds like you just need the upper shock mounts to complete the front assemblies.
MicMul is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 10:11 AM #9
jcaino jcaino is offline
jcaino will become famous soon enough
Yea, you'll need to get the top strut mounts - kyb makes them and they're pretty cheap.
I wouldn't bother assembling them beforehand, I think it's actually way easier (and safer) to use the weight of the vehicle to compress the coil and get everything bolted up.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam, Pioneer Sub | LED bulbs
Outside: LED Ditch lights on CBI brackets | RCI skid plates | RCI rock sliders
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-505 | Airlift bags | Cooper S/T Maxx 255/75/17
Planned: Lo Pro bumper | Winch | Wheels & Tires | Speakers
jcaino is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 10:31 AM #10
TodiN's Avatar
TodiN TodiN is offline
Real Name: Todi
TodiN is on a distinguished road
TodiN's Avatar
Real Name: Todi
Spring compressor method if not done properly can be dangerous. I’ve used the no spring compressor method as mentioned before, see this video: YouTube . Make sure you torque everything per specs.
When/if you return the truck, you can then remove all assembly and return the truck to original state.
2018 TRD OR
- SSO Full Rack; FJ TRD Pro Kit with: Front - 1.25" Lift Poly Front Coil Preload Spacer Kit (DAY TA3273), Rear - Eibach E30-82-071-01-02; M.O.R.E. aluminum full set skid plates; RCI front filler skid plate; removed Spidertrax wheel spacers; Pedal Commander; ARB diff breather; on-board Smittybilt 2781 Compressor on C4Fab second battery tray; Falken Whildpeak AT3W LT285/70-17 E
TodiN is offline   Reply With QuoteReply With Quote
Old 12-14-2019, 05:54 PM #11
jackacc's Avatar
jackacc's Avatar
Thank you for the info guys, the no spring compressor method looks much easier. I think I will go that route.
The rears shouldn't be too different from all the Jeeps I've lifted in the past.
assemble , install , parts , set , springs
HTML code is Off
FS: 5th Gen (2016 Trail) Front Coilover Shocks & Rear Shocks/Springs $175, West LA rgoodman00 For Sale: Suspension/Wheels/Tires 3 01-28-2016 03:22 PM
: 3rd G FS99 Tall Springs F+R and Front Shocks, 4R Wheels and tires, 97 springs SoCal mydogsmonkey For Sale: Suspension/Wheels/Tires 1 07-11-2014 10:36 AM
Getting Rid of OME Shocks, Springs, Front lift 5th4runner 3rd gen T4Rs 5 04-08-2014 02:00 PM
'99 front springs/shocks w/spacer & rear springs Full_Throttle For Sale: Suspension/Wheels/Tires 10 09-18-2012 11:57 PM
FJRunner lift installed (FJ springs/shocks and front spacer) gaberelli 4th Gen T4Rs 13 11-07-2009 10:35 PM
Copyright © 2019
