Old 12-27-2019, 10:22 PM #1
Jake0807 Jake0807 is offline
Jake0807 is on a distinguished road
ARB Twin Compressor - NEED HELP
Hey everybody!
I’m in need of help. I’ve seen a fair number of posts about compressors, how to wire them, where to mount them etc but nothing really touches on the problem I’m having.
So I just got the arb twin compressor and have it wired up. It will turn on and put out some air but when I go to inflate the tires, they actually end up deflating. My Viair portable comp puts out way more air so clearly I’m doing something wrong. Wtf!! I’m at a total loss.
I’m using the Rago mount that goes right behind the stock battery. It took me a while because I’m definitely new to the wiring world but it finally turned on. I followed the instructions for the power running to the compressor from the battery ( I have an odyssey deep cycle battery ). Both red wires with fuses to battery positive. Both the large and small black wires to battery negative.
This is where I changed things up a bit. I never intend to run a front locker and I would rather have a switch under the hood instead of in the cab. So instead of going through the trouble of taping up the solenoid connectors and trying to stuff all the wires for the 3 switches somewhere, I chose to cut all of that off. What I am left with are the black and purple wires that run into the compressor. I followed those wires on the schematic provided by arb and saw that they go to the red and black wires which in turn go to the power and ground on the isolation switch. To wrap this up I ran the purple wire to a blue sea breaker and then to the battery positive terminal. I ran the black wire to the battery negative terminal.
Any help would be greatly appreciated. I’ve been messing with this for the past day and a half. I’m guessing it’s user error but I’m not sure what else to try.
Thanks in advance and I hope everyone is having a great holiday.
Jake0807 is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 10:29 PM #2
To clarify the part about the blue sea breaker. I am using that as the switch to turn the compressor on and off. It works as I intended, it just isn’t giving me the air pressure I was expecting, to the point of being unusable.
Old 12-28-2019, 10:52 AM #3
<<<<'s Avatar
<<<< <<<< is offline
<<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice <<<< is just really nice
<<<<'s Avatar
Are you using Lead hose from compressor or have quick connector right at the source?
<<<< is offline   Reply With QuoteReply With Quote
Old 12-28-2019, 10:59 AM #4
<<<<'s Avatar
<<<<'s Avatar
Either way, take out lead hose if applicable and use ARB quick connect directly with aluminum elbow. Do not over tighten it, because it may crack the manifold and cause the leak. Also use sealer or Teflon tape on your connections to stay airtight. GL
Old 12-28-2019, 11:33 PM #5
[QUOTE=
I’m using the arb quick connect that the compressor comes with. I did forget to use the tape at first but went back and used it with no better result.
Old 12-29-2019, 10:03 AM #6
<<<<'s Avatar
<<<<'s Avatar
If you don't see major leak source anywhere, then you got bad solenoid since it is unlikely for both pistons of twin to be faulty at the same time. I'd send it back and get replacement.
Old 12-29-2019, 01:39 PM #7
[QUOTE=
Old 12-29-2019, 01:40 PM #8
[QUOTE=
Ya I think I’ve checked everything there is to check on my end. Bummer. Thanks for the advice.
battery , black , compressor , i’m , wires
HTML code is Off
ARB twin compressor for $442 <<<< 5th gen T4Rs 0 11-24-2018 09:10 AM
Where to mount an arb twin compressor? NWFLBowhunter 3rd gen T4Rs 11 12-11-2016 12:37 PM
Questions about ARB twin compressor mavrick1903 General Discussions 2 01-20-2016 01:29 AM
ARB Twin Compressor air tools; which do you use? Okki 5th gen T4Rs 1 06-16-2013 12:35 PM
