Originally posted by Bigstr8edgeRed
So what is the lowdown on the aftermarket stereo deal on the new 4Runner's. I am looking at getting an '04 Sport Edition V6 with the standard Toyota stereo. I want to up grade to an aftermarket standard CD player and possibly nicer speakers. A couple of ?'s though. I know I am going to loose the steering wheel controls which sucks, for any one who has done this does it bother you? 1. I have seen the after market dash kit what is with the storage space under the deck? 2. Will I need to get an amp to power the 6 speakers if I replace the standard Toyota 6.
you can install any aftermarket radio on any vehicle
good luck and just pick the one you want.
Check out this guys site for more info on radio installs.
http://www.br00klyn.com/4runner/
You can install an aftermarket radio and keep your stock speakers ( i have). or you can install an amp and power them separately (which is better for sound quality) but stock is fine.
As for warranty. the only part that will become void is the radio. Anything you change will void only that part of the warranty (actually only if they know it was there or changed).
Just because you changed your radio and now the suspension is all messed up doesn't mean that they won't warranty your suspension. A void warranty only affects those that are the root cause. If the radio did infact break your suspension (somehow) then I guess they can say so.
If the dealer says otherwise regarding warranty, take your business elsewhere. Keep in mind that any TSB repairs are performed regardless of warranty since it is a safety recall.
