Old 01-10-2020, 06:19 PM #1
judoant's Avatar
judoant judoant is offline
judoant is on a distinguished road
judoant's Avatar
Light bar wiring harness
I just bought a 540w light bar and need a harness. I can’t find anything that goes much over 300w. I found a mictuning 600w but I think it’s for 2 300w connections. I am afraid the 12 awg wiring per light might not be sufficient for the bar I have.
99 4 Runner Limited. 3" Toytec Ultimate lift with SuperFlex rear coils. 231mm Tundra calipers. Rear diff breather extension. 285/75-16 Nitto Trail Grapplers. Savage full skids & sliders w/ kickout. ISR mod. LED gauges. Shrockworks front plate bumper w/ loop. 4xInnovations rear plate bumper.
judoant is offline   Reply With QuoteReply With Quote
Old 01-10-2020, 07:06 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Do you have any more information, perhaps a link to the bar itself?
I seriously doubt your lightbar actually uses that much juice. 540 watts at 12 volts is 45 amps of current. That’s a ton of power for a light bar, even a good one.
I recommend you try and measure the actual current draw. Just as an example, this is a “120 watt” light bar, which uses no more than 50 watts in operation.
12.30 x 4.01 = 49.32 watts
Generally speaking, I have found a 12 AWG wiring harness with a 30 amp relay to be more than adequate for almost all lighting solutions I have seen. Unless you are running something really special here, I would not be too concerned. That said, none of this means anything until you actually measure your load.
Old 01-10-2020, 10:05 PM #3
judoant's Avatar
judoant's Avatar
Here is the bar.
https://www.amazon.com/Nilight-18025.../dp/B07X9LB9G9
Here is the harness they just recommended
https://www.amazon.com/Nilight-Wirin.../dp/B074GYNJ85
Old 01-13-2020, 07:04 PM #4
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
I don't know if its posted wrong on Amazon but that thing is 30V.......
Not gonna work unless you got more to your set up.
*Edit
Well I scrolled down more and it says 9V to 30V. Amazing how Amazon has more product information than their own damn website.
12AWG should be good assuming you putting it upfront.
ampacity.jpg Photo by skylark462 | Photobucket
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 01-13-2020, 07:41 PM #5
Bumbo's Avatar
Bumbo's Avatar
Most lighting I have come across works on 12v and 24v systems, so 30v would be the top end of a 24v systems input voltage.
While I too use those ampacity charts, that one is a bit aggressive in its selections… 3 feet of 12 AWG has a 8% voltage drop with 100A going through it. That conductor would be smoking hot. I try and keep my voltage drop to no more than 2% to 3% ideally… 5% max.
I generally limit my 12 AWG conducts to no more than 30-40 amps depending on the application. Even if the conductor can handle it, the contact resistance of other connectors, like the spades connecting to the relay, would soon become the limiting factor and main generator of heat. Insulation temp ratings also play a very large role, meaning use quality wire.
The website specs don’t tell us much of anything. I would venture to GUESS, than the actual consumed power is 50% of what they advertise, meaning you might see a 20-25 amp load, making a 12 AWG wiring harness sufficient. Again, without measuring the actual consumption this is all speculation / best guess.
Old 01-13-2020, 08:06 PM #6
I just jacked the chat from the first google link I found.
I always measure mine for real world draw before wiring it up.
2018 TRD OFF ROAD
My Build
Old 01-16-2020, 10:51 PM #7
derbytown derbytown is offline
derbytown is on a distinguished road
I think as long as you use 12-10 gauge wire with a good quality relay you'll be ok, between mine, (light bar, large round bumper lights, ditch lights, another set of led bumper lights ) no hot wires even when everything is on. Just relay each light or set that you hook up.
derbytown is offline   Reply With QuoteReply With Quote
300w , bar , harness , light , wiring
HTML code is Off
URGENT: Tail light wiring harness - Which wire under power for backup? Okki 5th gen T4Rs 14 01-26-2017 11:33 PM
Light Bar Wiring Harness WhiteLightning 5th gen T4Rs 1 10-11-2016 08:43 PM
WTB: 2nd Gen 4R reverse light wiring harness mbrown Want to Buy/Trade 0 05-04-2013 07:45 AM
