Old 01-16-2020, 07:42 PM #1
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Greasing UCA's
How often are people needing to grease their UCA?
Got mine put on last year. Maybe less than 3 months later and not even 1k miles it was squeaking. Greased it and good to go.
Now fast today only 700 miles since greasing them it was squeaking at me again.
I loosen the UCA bolt. Grease it until it spills out. Wipe it up and tighten. 85ft/lbs.
Wrong grease maybe? I put maybe 2 - 3k a year on my 4R I figure it would be good for at least 6 months or every oil change.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 11:34 AM #2
Crikeymike's Avatar
Crikeymike Crikeymike is offline
Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of Crikeymike has much to be proud of
Crikeymike's Avatar
What brand of UCA's are you running??
Maybe they were greased wrong from the start. The OD of the bush and the ID of the eye is not to be greased. If the bushings are rotating there instead of in the middle where the sleeve is, that would cause extra noise.
I have Total Chaos UCA's that were properly greased when installed and I haven't touched them in a very very long time.
Exit Offroad - Specialist in Dobinsons Suspension & Accessories
Dobinsons | RCI | Powerbrake | Long Range Tanks | Timbren | Overland Vehicle Systems
Youtube Channel | Email Directly
Been in the offroad industry since 1998. Born & raised in Australia - currently in Jax Beach, FL. 2014 4runner Trail, 3/2" Dobinsons MRA Suspension, Shrockworks bumper and sliders, M8000 w/ Treaty Oak winch line, LFD Roof Rails, Dobinsons 2m Awning, RCI skids
Crikeymike is offline   Reply With QuoteReply With Quote
Old 01-24-2020, 12:37 PM #3
Icon's.
Install was done by DH when he came down from Vegas. He was very reputable before he moved so I'll side that it was installed correctly.
Doesn't look like its rotating on the outside of the bushing. Greased it and its good to go again. Just hoping I'm using the right grease.
2018 TRD OFF ROAD
My Build
Old 01-30-2020, 01:11 AM #4
Akkording's Avatar
Akkording Akkording is offline
Akkording is just really nice Akkording is just really nice Akkording is just really nice Akkording is just really nice
Akkording's Avatar
what grease are you using? I use O'Reilly autofarts lithium grease. AutoZone didn't carry Li at all
I run the same grease in my delta joints
2011 Starfire Pearl GX460 stock base ;)
2012 Blizzard Pearl SR5 | 285 Toyo OC AT3 | Level 8 Slam | YotaWerx ActiveDuty | Die Hard AGM w/ArcLightLeds V2 Booster | Borla 40665 | URD Y & MAF Cal TRD | C4 Center LP | Maxbore 2mm TB "loaner from my boy Dave" | X20 10k Factor55 | Shrockworks Armory | RCI LCA skids | TC Gusset | LFD Offroad 7/8 | TJM Airtec dry aFe HPS coupler w/TRD CAI tube | B8 6112 | 650# King | ICON Delta Joint | Fox 2.0 VS| SAW 1.5" |230k|
| 03 DCSB Tacoma OME equipped, +320k Still Truckin |
Akkording is offline   Reply With QuoteReply With Quote
Old 01-30-2020, 12:16 PM #5
Red Line Synthetic Oil. CV-2 Grease
This one.
2018 TRD OFF ROAD
My Build
Old 01-31-2020, 01:42 AM #6
delloro's Avatar
delloro delloro is offline
delloro is just really nice delloro is just really nice delloro is just really nice delloro is just really nice
delloro's Avatar
Most auto grease is Li-based, is it not?
delloro is offline   Reply With QuoteReply With Quote
Old 01-31-2020, 02:57 PM #7
Akkording's Avatar
Akkording's Avatar
no clue. I use what is labeled with Lithium
good , grease , miles , months , squeaking
HTML code is Off
Greasing UCA’s alextmullis Maintenance/Detailing 0 05-02-2018 01:29 PM
Greasing the driveline bucknasty07 4th Gen T4Rs 5 06-19-2017 12:50 AM
Greasing UCA's and Bushings propain 5th gen T4Rs 2 10-15-2016 10:42 AM
Greasing CVs trailsurfer92 4th Gen T4Rs 1 09-14-2016 08:56 AM
Greasing U-joints? spooner Maintenance/Detailing 9 02-29-2004 05:56 PM
