Old 01-18-2020, 06:42 PM #1
FamousAv8er's Avatar
FamousAv8er FamousAv8er is offline
FamousAv8er is on a distinguished road
Question Powered Sub Wiring
I purchased a Kicker HS8 Powered Sub. I am ready to run the wiring but I am not sure where I should tap into for the remote power/turn-on. I have a 5th Gen non JBL w/nav. Below is a wiring sheet I found online which seems to be fairly accurate. There is no Factory Amp or Power Antenna values which leads me to believe there may be non to tap in to. Where could I tap into for my remote power without affecting the performance of anything else?
Powered Sub Wiring-2012_3-jpg
Daily Driven '17 T-Force T4R - Baja Flat Rack - 5100s
odo: 80,000
FamousAv8er is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 06:58 PM #2
MikeyMTBs MikeyMTBs is offline
MikeyMTBs is on a distinguished road
What about the last one, “satellite radio ignition”?
It would be switched power...
MikeyMTBs is offline   Reply With QuoteReply With Quote
Old 01-18-2020, 07:00 PM #3
I would want to verify that that is 12V and I would want to assure that that would cause no issues with my satellite radio because I use that often.
odo: 80,000
Old 01-18-2020, 07:08 PM #4
It looks like another option would be to se DC Offset Turn-On but I will need to look at how to do this.
odo: 80,000
Old 01-21-2020, 10:38 AM #5
tylertenny's Avatar
tylertenny tylertenny is offline
tylertenny will become famous soon enough
tylertenny's Avatar
I currently have the same powered subwoofer mounted under my driver's seat. I bought the Kicker RCA adapter and a Toyota wiring harness adapter. This makes it a little easier to hook up and you won't have to splice into any wires in your factory harness.
I also mounted the remote bass controller into that small compartment in the center console. I'd still like to swap out some of the other speakers but so far I'm pretty happy with the sound after adding the Kicker subwoofer.
2016 SR5 Premium Pro Comp Series 32 Bandido wheels (17x9) * 265/70R17 KO2 C load * Eibach Stage 1 lift * JBA UCA * Energy bumps (F), Durobumps (R) * LFD 3/4 roof rack * BajaRack ladder * CTH TRD skid plate * CTH TRD Pro grille * TRD Pro front lower valance * Diode Dynamics SS3 Sport fog lights * R4T smoked sequential turn signals and CTH sequential side mirrors * black out emblems * Kicker Hideaway powered subwoofer
tylertenny is offline   Reply With QuoteReply With Quote
Old 01-21-2020, 11:49 AM #6
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
try using the radio ignition wire, that should be the acc or switched.
lt blue might be the constant power.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
power , powered , remote , tap , wiring
HTML code is Off
Powered Sub Wiring FamousAv8er 5th gen T4Rs 6 01-18-2020 07:09 PM
Under Seat Powered Sub honda99ex 5th gen T4Rs 6 03-03-2017 01:24 PM
Edmund's says 3rd gen under powered nick117201 3rd gen T4Rs 58 06-25-2014 02:34 PM
Under powered cement head 3rd gen T4Rs 4 01-16-2012 08:54 PM
Jet Powered MR2 DavidAlexander Off Topic 1 04-04-2009 01:23 AM
