Originally Posted by delloro
Sounds like a sticking valve.
Do a compression test, cold and hot.
Just did cold right now: all cylinders hit 125. I'll check hot once the rain stops.
Also noticed that the oil light stays on below 1000 rpm, and flickers/shuts off at rpm's above 1000.
Is an oil pressure check in order? Also the internet tells me a bad knock sensor could give me these knocking/low power symptoms. Planning to check that with the multimeter soon.
