Originally Posted by bradze
My 5th gen has a winch and bullbar, 285s, a prinsu rack, well let's just say it's about 400 lbs heavier than it should be. I want icon stage 7 but that's an insane amount of money and I don't really need it. I'm thinking about the bilstein OME setup that I see so much on here. What parts would that consist of? I'm thinking of Maybe adding total chaos upper control arms
I had the 6112 with 600lb springs and switched to 650. This is with extra weight only from skids and sliders (300lb total). It is not little, but not like bumper.
The 600 would be too soft for you, knowing you from the OB forum
This brings the question if 650 will suffice or if you will need 700. I'd say try the 650 first since you are far from the desert.
In the rear I run Icon 2.0 non-resi with 1" Eibach springs. Heavier weight will only make it better. No need for heavier duty stuff unless you are crazy heavy or crazy fast. This is plenty heavy duty enough.
I have 1.3/1 lift and don't hit thanks to the much stiffer suspension. I bet yours will 1-1.5 lift will perform WAY better than with a 3/2 spacer lift and the weak stock suspension. Both at speed and in the rocks. It will be in a whole different league, all for 1100-1200$ total.
