Old 03-18-2020, 11:56 PM #1
pableaux's Avatar
pableaux pableaux is offline
pableaux will become famous soon enough
pableaux's Avatar
Alignment issue or bad tire?
I recently got an alignment and I'm having a hard time believing it was even worth it.
I was originally noticing some bad wear/possible feathering on my front driver at 2k miles. Falken Wildpeaks.
According to this printout, the only thing out of spec was my front passenger and my front driver was within spec. I also don't understand how 0.01 degrees on the right is worse than the left. I know I should have asked them before I left. I was in a rush and had to leave.
Do I have a bad tire or was my alignment causing the issue?
pableaux is offline   Reply With QuoteReply With Quote
Old 03-19-2020, 12:09 PM #2
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
.01 is right on the edge of being out of spec so it is possible.
They got it more in the middle so I'd just keep an eye out for it now.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 03-23-2020, 07:59 AM #3
chaz's Avatar
chaz chaz is offline
chaz will become famous soon enough
chaz's Avatar
to me that wear looks normal for falken tires, they seem to round off easier.
chaz is offline   Reply With QuoteReply With Quote
Old 04-11-2020, 11:03 AM #4
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
You're in Northern Virginia. When I lived there I had increased wear on the fronts due to all the on and off ramps and suburban driving. You said, "front driver" in your post, is this a T4R or a different vehicle?
Either way, your solution will be to rotate frequently, I'd go not more than 4 or 5000 between rotations....and this is not only my advice but the advice from my tire shop when I went in with the same issues and my alignment was right on.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
alignment , bad , front , issue , tire
HTML code is Off
Alignment Issue prybar 3rd gen T4Rs 1 02-16-2020 02:16 AM
Alignment Issue BRUIN8124 4th Gen T4Rs 1 07-31-2018 11:56 AM
Alignment issue help. Pulling to right but alignment OK jason2000SR5 3rd gen T4Rs 44 02-15-2018 10:56 PM
Alignment issue. Help needed CalBlackSheep 3rd gen T4Rs 6 11-23-2017 02:01 AM
Alignment issue otbexige 4th Gen T4Rs 3 04-09-2011 08:07 PM
