Old 04-03-2020, 02:17 PM #1
tubbs831's Avatar
tubbs831 tubbs831 is offline
Real Name: Keith
tubbs831 is on a distinguished road
tubbs831's Avatar
Real Name: Keith
ARB engine bay mount?
Looking for options to mount an ARB and fuse block in the engine bay. I know there are some out there and i have seen them but i don't know what key words to search. Something similar to the Power Tray option. Any help is appreciated.
POWERTRAY LINK
1990 Toyota 4runner | 243K miles | Sold
2010 Toyota 4runner | Bilstein's with T1 coils in the front and T13 coils in the rear (2.5" lift up front and 1.5" in the rear.) and JBA UCA's. Method wheels with zero offset wrapped in 285 Wildpeaks.
tubbs831 is offline   Reply With QuoteReply With Quote
Old 04-03-2020, 05:26 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
ARB makes a lot of stuff, but I assume you are referring to the air compressor?
You don't need everything to go on the same mount... most installs I see for the air compressor are on the passenger side with most general electrical on the driver.
Some systems require a PS relocation kit depending on the generation of 4Runner and the pump you select.
"(x)th gen 4runner arb compressor mount" would be a good place to start.
As for the fuse block, unless you are running a variety of electrical accessories, you could get away with less if its just the compressor, or you could buy into a system.
You have a lot of options, including just making something custom, which is what I did.
A good starting point would be to list out all the electrical modification you want to make first so you can pick a load center that works best for you.
Old 04-04-2020, 12:02 AM #3
tubbs831's Avatar
Real Name: Keith
tubbs831's Avatar
Real Name: Keith
Yes, it's for my 5th gen and I have the fuse block right now but am looking into the single compressor and it could fit on the passenger side together. From the link I posted before.
Would you mind sharing what you made?
Sent from my SM-G950U using Tapatalk
Old 04-04-2020, 02:25 PM #4
Bumbo's Avatar
Bumbo's Avatar
If the bracket you posted works for you, then I would say you already found what you need.
I don’t really have good work in progress photos… I just walked around Home Depot and bought various metal angle and L brackets and drilled them out to make it work under the hood to hold various items securely.
My air compressor isn’t under the hood for longevity / heat concerns. I have a portable on an Anderson quick disconnect in my grill.
I'm actually inflating my air mattress here... but you get the idea.
arb , bay , engine , mount , search
HTML code is Off
OEM Engine/transmission mount replacement fourfive 3rd gen T4Rs 32 03-21-2019 04:19 PM
Dual Compressor Mount for drivers side engine bay? TerraCrawler 5th gen T4Rs 6 10-17-2017 11:41 AM
Engine and trans mount upgrades? TopElement Classic T4Rs 2 01-31-2011 06:44 PM
engine mount problem!?! monkeybono 3rd gen T4Rs 3 01-09-2009 07:02 PM
