Old 05-02-2020, 10:31 PM #1
Kyle B Kyle B is offline
Kyle B is on a distinguished road
Help with installing Toytec Boss Aluma 2.0 on KDSS 4Runner
Today I attempted the install of my lift, but I had to give up. Before I completely throw in the towel and pay for the install, I wanted to see if anyone had any insight for me. I removed the upper control arms, I opened up the KDSS shutter valves, I removed the front sway bar at the KDSS piston and hard mount, and I removed the bolts from the lower control arm ball joints. I was able to get the boss Aluma 2.0 driver side strut assembly in place, but the bottom bolt hole was way too low, and I could not get the lower control arm to go any lower. Any ideas to either compress the strut assembly or lower the lower control arm a little further? I did try compressing the spring, but it didn't seem to compress the whole strut assembly.
Thanks
Sent from my Pixel 2 using Tapatalk
Kyle B is offline   Reply With QuoteReply With Quote
Old 05-04-2020, 01:10 AM #2
From what I can tell there are only two additional options. I can detach the sway bar at the LCA, but will that allow the LCA to drop more? Or, I read that if you loosen the rear LCA cam bolt the LCA can drop 180 degrees, but they tend to cease and might not be a good idea to do myself?
Old 05-04-2020, 04:48 PM #3
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I assume you've solved your problem by now but yes, mark the position of your LCA cams and then loosen them up and push the arm down so you can line up the bolt hole, then reassemble.
Old 05-04-2020, 06:27 PM #4
Thanks. Not sure why this isn't mentioned in any instructions or videos, but seems like what I have to do.
Old 05-08-2020, 04:30 PM #5
HOJeepster's Avatar
HOJeepster HOJeepster is offline
HOJeepster will become famous soon enough
HOJeepster's Avatar
Or use a pry bar to lower the UCA's more.
HOJeepster is offline   Reply With QuoteReply With Quote
arm , assembly , control , kdss , lower
HTML code is Off
Toytec Aluma Series Boss Kit MOONMAN5 5th gen T4Rs 2 08-24-2019 10:26 AM
New Toytec Boss Aluma Series Kit and Dobinsons Upper Control Arms MOONMAN5 5th gen T4Rs 0 07-31-2019 02:30 PM
Toytec Boss Suspension System w/KDSS NC_High_Country Engines / Suspension / Wheels / Tires / Audio / Accessories 1 06-08-2019 08:26 PM
FS: Brand New Toytec Boss Lift- 5th GEN T4R non KDSS - $1200 - MA reign1 For Sale: Suspension/Wheels/Tires 0 05-11-2017 02:20 PM
Toytec Boss w/KDSS install question Sig_Fan_55 5th gen T4Rs 21 08-26-2016 05:15 PM
