Old 07-01-2020, 11:14 PM #16
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Originally Posted by Nasdaqer2300 View Post
I just installed a Sony XAV-AX3000 in my son's 2008 Limited. Actually, I should say we had it installed. Although we have done other installs, this one seemed more complicated. Truck has the JBL NAV.
Since we had the stereo installed, it sounds like the sound quality is actually worse
Is it possible the installer missed something? I mean its not a train wreck, but its definitely more "muddy" or something, if that makes sense. Has anyone ever dealt with this before? Is this Sony unit just not great? Would it make sense that the sound quality with the stock head unit is better?
Would love to hear any input.
Thx!
So depending on how it is wired, there can be serious issues when converting from the JBL amp. A good install should use the low-power RCA outputs to feed the JBL AMP, which would allow the JBL amp to still power the speakers exactly as it did from the factory unit. You can try playing with the bass/treble settings. On my 3rd Gen Limited I put in Pioneer unit with HPF set at 50hz. It just knocks out the deepest bass, but you still get the full sound without the muddiness. The stock headunit cuts off around 35hz I believe.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 05:47 PM #17
Drifter2080's Avatar
Drifter2080 Drifter2080 is offline
Drifter2080 is on a distinguished road
I've never had any luck with the android head-units, they have all ended up sounding bad.
2001 4Runner SR5 455k (5mt Swapped)
2017 BMW M2 6MT
2008 BMW M3 E92 6MT
1998 BMW 328ic 5MT
2008 Mercedes-Benz C63 AMG & CLS63 AMG
Drifter2080 is offline   Reply With QuoteReply With Quote
Old 07-12-2020, 06:01 PM #18
ajw1275 ajw1275 is offline
Real Name: Adam
ajw1275 is on a distinguished road
Real Name: Adam
I like the layout screen of that headunit
ajw1275 is offline   Reply With QuoteReply With Quote
Old 07-16-2020, 02:26 PM #19
riverwolf riverwolf is offline
riverwolf is on a distinguished road
Thx!
The JBL amp is expecting a digital signal from the head. You'll need a Toy/JBL system specific adapter to convert from either the preamp or speaker level outputs into a digital signal the JBL amp understands. There are/were a couple of different options on the market...check Cruthchfield for details.
Assuming your installer actually used one of these adapters, they still have some very specific steps that need to be done before the factory JBL head is removed. All of the bass/treble/surround/volume is actually set in the JBL amp, so the adapter instructions tell you to set bass/mid/treble to 0, turn the volume to or at least near maximum (don't know how high it goes), and surround is just a preference....before you remove the factory head unit.
If the installer didn't do one or all of the prep steps, your muddiness could be too much EQ...whatever tone adjustments you're doing in the Sony are running on top of whatever bass/mid/treble settings were left in the JBL before removal.
Similarly, at least one of the adapters had some level adjustment ability to help match the drive level of the aftermarket unit to the sensitivity of the JBL amp. If not done correctly, bad sound could happen.
The other option is your installer tried to bypass the JBL amp and run the speakers directly from the Sony's internal amp. This could cause all kinds of bad due to impedance mismatches and misconfigured crossover settings...the various channels of the JBL amp do some crossover and EQ of the signal depending on which speaker channel its feeding (FD/RD/Sub/Center Front/Center Back).
So, to do any troubleshooting, you need to know exactly how your installer integrated the Sony with the JBL amp.
Good luck!
2003-2022: '03 Limited V8 4x4 - Galactic Gray Mica
2022-Present: '21 Nightshade 4x4 - Magnetic Gray Metallic
riverwolf is offline   Reply With QuoteReply With Quote
Old 10-16-2022, 07:04 PM #20
jrm's Avatar
jrm jrm is offline
jrm will become famous soon enough
jrm jrm is offline
jrm's Avatar
ATOTO A6 PF Android Double-DIN
Hey. What do i need to install this HU in a 2000 3rd gen limited? Im no mr. wizard so id like to keep it p&p. If this HU isnt P&P cant you rec one that is for at around the same price point.
jrm is offline   Reply With QuoteReply With Quote
android , cameras , good , head , units
HTML code is Off
Scion Head Units westcan Engines / Suspension / Wheels / Tires / Audio / Accessories 73 04-23-2021 08:50 PM
Head units: what are you running? Toyot@ 4th Gen T4Rs 12 06-18-2018 12:40 AM
Head to Head : Android Auto vs Apply Carplay NoDak Off Topic 1 12-01-2014 10:53 PM
In dash head units! ToyotaJoe01 3rd gen T4Rs 8 08-09-2013 07:05 PM
Clarion Head-units?? CartersYota Engines / Suspension / Wheels / Tires / Audio / Accessories 4 04-09-2011 11:25 PM
