01-19-2004, 11:34 AM
Here's Some Help with Navigation Install
To All:
I recently installed the Toyota Navigation system from oemvalue.com in my 2003 4Runner Sport. There were a few issues I had in getting the system to work 100% (speed & reverse sensor, antenna amplifier). After a lot of research, the job is complete and I put together some instructions/downloads for anyone looking to complete the same.
Since there is a lot of data from the Shop Manuals, I put a link to my website so you can download.
Good luck and let me know what you think.
http://www.norgetech.com/navsup.htm
Pete
01-20-2004, 01:04 PM
Wow! You really did your homework. I have a connector on the way, and I am going to do the splicing next week! Thanks for posting this info...
Mark
01-21-2004, 09:23 PM
Navigation install
Hi Pete,
When installing your navigation system, did you you have any problems with no sound. Oemvalue told me that it will work but without sound. He told me to do some research on a 20 pin connector to power the amplifier. I was wondering if you can give me some input on this situation. Thanks
Nick
01-22-2004, 11:29 PM
Hey Pete,
Great job on the nav installation!!!!
I just purchased a system from the oem folks, but I have a 2004 4runner ...do you think the installation will be much different?
thanks
Juan
01-23-2004, 06:20 PM
It will be different in that I believe the 2004 is based on the all in-one-NAV system instead of the ECU being in the back of the truck. This is for the better though as your connections should be all up front. I can't stress enough that it is important that you either buy the Toyota Electrical Manual for your truck or make friends with someone who does
Pete
01-24-2004, 08:52 PM
Re: Here's Some Help with Navigation Install
Originally posted by petegaz
To All:
Pete
Hey Pete,
Your write-up is simply great. I've been trying to figure out why my radio reception stinks for quite a while and the missing antenna amp is clearly the answer. However I couldn't quite tell which wires you were talking about in the picture on your site. I was wondering if you could take a quick look at the pictures and then tell me which colors I should be looking for. My system was replaced by a pro so I didn't have the experience of taking every thing out. Now that I've done some smaller projects behind the dash I'd like to take this one on, but without having the old connections to examine, I'm not quite sure which wires I'm looking for and was hoping you could help point me in the direction of the two antennas and the the wire that needs power.
Thanks a lot!!
Erik
2003 Sport Edition 4WD V6 (Titanium)
K&N AirCharger Intake
Dual Borla Cat-Back Exhaust
AVS Tail Light Blackouts
SuperWhite XD5 5800K Head Lamps (Lows, Highs, Fogs)
Customized Wet Okole Neoprene Seat Covers
V1 Hardwired w/ Concealed Display Unit
Westin Light Bar
IPF J0-1 2-in-1 Fog and Driving Combination Lights
An interesting sound system...check out my thread HERE (updated 08March04)
01-25-2004, 08:30 AM
Actually it is pretty easy on this one. You should remove the radio (I think you will have to in order to get to the antenna signal cables). Then you should notice two antenna signal plugs that plug into the radio (one bigger than the other). I believe this is for diversity signal reception. Follow those two cables back about 6 inches and you will see that they combine together inside of a cable cover. You should also notice a third cable that is in that same cover. It will be a black, approx 18-20awg cable with a white, single connector on it. That is the cable going to the antenna amplifier. You will need to get power to this. If there is another connector attached to this, you may need to trace that to the radio and make sure where it is terminating there is power. In either case you can tap into this cable and apply 12v. After doing this the reception should be restored. It was in my 4Runner.
There should be a picture of this in my directions, but it may be a little zoomed in.
Good Luck.
Pete
01-25-2004, 04:50 PM
That is tempting, but for $1700? Would it be nicer than the best Garmin or Magellan has to offer?
I have a small Garmin I use on my bicycles and in the cars. Doesn't talk to me or anything, but it works quite well.
01-25-2004, 10:00 PM
I emailed you, but perhaps it didn't get to you...How exactly did you hook up an external amp? I am trying to figure out how to get more juice to the rears and maybe power a small sub...Did you create rca line outs? Just curious...I just got the wiring stuff from oem and I will tackle the voice nav and antenna booster project next week sometime...Thanks again for sharing the fruits of your hard work!
Mark
01-26-2004, 12:28 AM
SpyderDoc:
For the amp/speakers work, I brought it to a stereo place because they have done this a lot more times than me. I had done too much work on it to screw it up with the amp and speakers. They installed a line unit that converts from a cable to RCA input and that went to the amp. They tapped the signal inputs from the NAV to the amp. Now, the only reason the JBL amp is in the car is for the power inputs, ground, etc. See the pics below that might help.
01-26-2004, 12:29 AM
Not sure why the pic didn't get attached.
Here is the pic:
01-26-2004, 01:07 PM
Thanks for the info...I hear ya...I guess it's time to suck it up and bring it in to have someone else do some work on it...
Mark
02-03-2004, 11:01 PM
Nice write up! There is one thing that I'm still confused about. Why did you end up putting the JBL amp in the glove box? Isn't there a factory mounting point for it somewhere under the dash?
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04
Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver
Future Mods: 115V Inverter, Leather, Trip Computer Fix
02-04-2004, 08:45 AM
On the '03, like I have, the amp goes in the back of the truck. That wouldn't have worked out well with the 2004 Camry Nav System install from Oemsales.com. I tried to find another place in the dash, but it is real tight in that dash. I didn't want to cause any problems with the passenger airbag either. The '04 might be different.
02-04-2004, 12:39 PM
I just installed the OEM unit on a 04. Pete's instructions are exactly right. The amp needs to go in the glove compartment as well...there's no room anywhere else upfront. One thing that is different is that I did not have to supply power to the antenna, the reception is perfect without it!
HTML code is Off
