Thread Tools Rating: Thread Rating: 3 votes, 1.00 average. Display Modes
Old 06-08-2020, 03:27 PM #16
02SE 02SE is offline
02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold 02SE is a splendid one to behold
Originally Posted by Thai View Post
Yeah, in the TireRack test, KO2 hung with the leaders, even in the wet. Again, this was a Heavy LT tire vs. much lighter weight P-metric competitors. Even TireRack was surprised how well KO2 did on-road! And surprisingly, it was not the worst in fuel economy either!
BTW, i drive between Texas and Colorado often in all types of weather. Never felt KO2s were unstable or slippery. Now, i do drive sensibly.
I had KO2's on another SUV. I've had lots of other A/T tires. I can tell you that in comparison, they aren't great in the wet. They have the classic BFG A/T look. I've had sets of them since the 80's. The KO2's are better in the wet than the KO or older versions, but even Tire Rack stated they would like more wet grip.
You can see from the picture I posted, that I'm running the deeper tread LT Yokohama Geolandar A/T G015. Shortly after I installed them two months ago, they've been in downpours, and snow. They did much better than the KO2's I also owned. They are as quiet as the OEM Dunlops it came with, They balanced easily with no vibration or shimmy at any speed, and only a slightly firmer ride due to the LT construction.
Tire Rack also stated that their fuel economy numbers are not a highly accurate test. But tire engineers will also tell you that to get great wet grip, some fuel economy is sacrificed. I ran a few tanks through my 4Runner with the OEM Dunlops, and have run some tanks through with the Yokohama's. Surprisingly to me, I haven't been able to detect much change in MPG at all, despite driving the same roads, in the same driving style, and using the same gas pump.
02SE is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 03:42 PM #17
Thai's Avatar
Thai Thai is offline
Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold Thai is a splendid one to behold
Thai's Avatar
Maybe my tread are still good...thus, i have not noticed any wet issue.
Yoko G015 LT was my 2nd choice but it did not come in stock size (for Land Cruiser)...only P-metric available. I did consider a skinnier size but it was Load Range E and was just as heavy as KO2 in Load Range D in stock LC size. It’s been a great match with my LC so far.
My other choice was Michelin Defender, which i love.......but that damn minivan-look!
My 2019 Land Cruiser
My 2023 Ford F150 Platinum FX4 Powerboost with 7.2 kW ProPower Onboard
2023 Lexus GX
2024 Subaru Impreza RS
Lets Go Brandon!
Thai is offline   Reply With QuoteReply With Quote
Old 06-08-2020, 03:56 PM #18
I'm running the E load range Yokohama's, in the stock 265/70R17 size. They are a bit taller than most tires in that size at 31.9" vs 31.6" most others in that size run, and they have 18/32nds tread depth. The KO2's have 15/32nds, the New Toyo's 16/32nds. All LT sizes.
I looked at and considered the new Toyo Open Country A/T3's. Compared them all side-by-side. I had the Toyo A/T2's in my 3rd gen. They were like the KO2's I had, good in dry dirt, not so great in the wet.
The new Toyo A/T3's supposedly have improved wet grip, and are now 3PMS rated like the BFG and Yoko. We get tons of snow. But I suspected they would be louder than the Yokohama's.
Ultimately I went with Yoko's because I've always have a good experience with their car and truck tires, they were on flash sale of $100.00 off for a set of 4, a manufacturers rebate of $60.00 off a set of 4, they matched the lowest Walmart price, and I was getting $100.00 for each of my stock Dunlops.
I couldn't beat the deal, and I have been very pleased with them so far.
Old 06-08-2020, 04:00 PM #19
Thai's Avatar
Thai's Avatar
The new Toyo A/T3's supposedly have improved wet grip, but I suspected they would be louder than the Yokohama's.
Discount Tire gave me $100 per tire off for my Dunlop stock tires! So, i saved $400 off KO2’s. How can you turn that down?!
A guy i know with Toyo AT3 did not like it. Had a sidewall puncture too. So, you picked good IMO.
2023 Lexus GX
Lets Go Brandon!
Old 06-08-2020, 04:03 PM #20
BTW the Landcruiser is a sweet ride. I considered one. Had an FZJ80 with front and rear e-lockers back in the day. The 200 series is nice. If we could get the Diesel version, I'd have one.
Old 06-29-2020, 10:10 PM #21
truc.karl truc.karl is offline
truc.karl is on a distinguished road
I've had my BFG KO2's for around 5 months and so far haven't let me down. These tires have great traction off road. They are fairly smooth on the pavement. Bought them because of the discount I got from 4wheelonline.
truc.karl is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 10:23 PM #22
Six_Actual's Avatar
Six_Actual Six_Actual is offline
Real Name: AJ
Six_Actual will become famous soon enough
Six_Actual's Avatar
Real Name: AJ
As long as you're looking at the BFG T/A KO2's perhaps look at the General Grabber A/Tx ...but as others said, for what you're doing you really don't need to change your tires. Good luck in your search!
Six_Actual is offline   Reply With QuoteReply With Quote
Old 07-01-2020, 11:03 PM #23
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Perfect off-highway tire = LTX? What? | Expedition Portal - This guy has conquered many crazy trails on the Michelin Defenders LTX. I've got them on my 2001 Limited, but have yet to have the opportunity to go on the trail with it. My LC100 had the LTX's on it, and they were amazing on-road. The testimonials from Expedition Portal say it is one of the best you can get. It's hard to beat a 60k mile tread warranty and having the tire outlast that!
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 07-02-2020, 09:38 PM #24
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
I had the Defender LTX for 5 years & 65K miles and went all kinds of off-the-pavement places on them. I highly recommend them but decided to go with another Michelin product this time around, the LTX A/T2. Love them so far on the road and the trail.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 07-03-2020, 12:57 PM #25
Banned
Real Name: Mark
ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future ElectroBoy has a brilliant future
Banned
Real Name: Mark
I agree. I’ve been running Michelins for over 20 years, six sets of LTX and M/S versions (not the latest Defenders), and now I’m using the AT2s. 20,000 miles on them so far, and they’re great on road and off. I don’t do anything severe or rock crawling though, cannot vouch for sidewall strength.
Old 07-03-2020, 10:41 PM #26
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
I’ve been very happy with my Yokohama Geolandar G015 A/T in 255/75r17, a 32.1” diameter tire. I think they were only $160/tire incl. delivery to my house in 2018. The Michelins are very good tires, but more expensive (>$200/tire). I have never owned BFG tires.
ads2539 is offline   Reply With QuoteReply With Quote
Old 07-05-2020, 11:35 AM #27
Shiftless Joe's Avatar
Shiftless Joe Shiftless Joe is offline
Shiftless Joe is on a distinguished road
Currently have a little over 40,000 miles on Cooper LT rated AT3's on the '05 Sport 4x4, still great in the snow and rain.
Much to my surprise, the Yokohama Geolander's that came on my used '07 Sport when I bought it have been the best all-around tires I have ever owned.
BFG's have been riding on their rep for a long time, would not be my first choice again.
Shiftless Joe is offline   Reply With QuoteReply With Quote
Old 07-06-2020, 05:46 PM #28
Drifter2080's Avatar
Drifter2080 Drifter2080 is offline
Drifter2080 is on a distinguished road
The Goodyear Wrangler Duratrac has been the best truck tire for me in Ontario, quiet on the highway, great in snow, good in rain and dry!
2001 4Runner SR5 455k (5mt Swapped)
2017 BMW M2 6MT
2008 BMW M3 E92 6MT
1998 BMW 328ic 5MT
2008 Mercedes-Benz C63 AMG & CLS63 AMG
Drifter2080 is offline   Reply With QuoteReply With Quote
Old 07-11-2020, 01:49 PM #29
GupsT4R's Avatar
GupsT4R GupsT4R is offline
Real Name: Ken
GupsT4R will become famous soon enough
GupsT4R's Avatar
Real Name: Ken
Originally Posted by kaitlyn2004 View Post
Picking up my new 2020 TRD off-road next week and looking to change the tires.
I live in Vancouver, BC so driving consists of MAINLY pavement 90% of the time
Rain, gravel roads, rocky "roads", maybe some minor sand, and (generally) wet snow
Would prefer to just have 1 set of tires I think. I think I've heard the KO2s are a good set? I'm not doing any SERIOUS mudding/offroading/etc. These are also 3-peak snow rated, so great for winter driving.
If I could get any more ground clearance from the tire, that's a bonus... but also definitely don't want anything that would require body changes or REQUIRE a lift to support
I've never bought tires in my life... so yeah...
ID say for mild snow to generally wet conditions out in BC and 90% pavement driving Michelin Defender LTX
2008 SE 265/70/17 BFG. SpiderTrax 1.25" Wheel Spacers - Sold
2018 Blizzard Pearl Limited - Stock
GupsT4R is offline   Reply With QuoteReply With Quote
Old 07-31-2020, 07:32 PM #30
miller507's Avatar
miller507 miller507 is offline
miller507 will become famous soon enough
miller507's Avatar
Nobody showing love for the Hankook Dynapros I see
My unbiased opinion... it's a well all around tire, good road manners in wet and dry conditions, quiet until they are worn out, then again I have a catback so my noise standards might be different than others.
I had the ATs and switched to MTs with no regrets, my T4R is a daily/weekend warrior so It's nice to have a set of tires that can handle both, my current set has around 30-40km and show little wear.
LC Prado 150
4th Gen 4Runner
1GR-FE
OME Springs w Bilstein 5100F&R, Durobumps bumb stops, Toytec 1" BL, Exhaust cam gears with 3° retard, Prado120 Snorkel, AFE Stage 2si, Magnaflow Catback w/ dual side exit 285/70R17 Dynapros MT Energy Suspension Bushings all around
miller507 is offline   Reply With QuoteReply With Quote
driving , roads , set , snow , tires
HTML code is Off
20" Limited tire recommendations jpuras 5th gen T4Rs 76 01-03-2022 08:54 PM
Largest tire "sizes" for stock 17" rims??? Lyric 4th Gen T4Rs 55 04-22-2021 10:38 AM
Seeking recommendations for "Durable" Dog Seat Cover El Burro Guapo 5th gen T4Rs 8 03-25-2020 07:22 PM
3"-4" lift kits for a '99 sr5? Recommendations? D-Mc 3rd gen T4Rs 5 04-12-2010 09:24 PM
