Can someone help me out with the install. I am having trouble locating the speed sensor wire.
I have the following items on my AVN6610
The bluetooth, Ipod (ipc106) and Camera (bec106)
The instruction from Eclipse did not help me much at least on the Parking and Speed Sensor tapping. However for the Reverse I followed exactly what they have instructed, tap it to the reverse light bulb. As for the Parking I was told it can be grounded to anywhere and for the Speed Sensor (eclipse manual is useless only say its on the ecu and does not tell what color the wire is) wire it should be located behind the A/C (right below the oem hu, on the black connector where it should be purple /red strip ( i actually have a total of 4 wires but many people on the forum only mentioned 3) anyway I have tried all 4 wires and none of them seem to work. All my lights turns on (check engine, vsc, vsc trac) after driving 1-2 miles. if speed sensor wire is tapped correctly it should show in the main menu > info > system setup?
When I am in the system setup screen the on the impulse speed it doesn't move and saying studying....
below are a list of results that I found but i cant seem to fix the problem i am having.
I also notice there is a beep sound each time I turn on the truck. is this the bluetooth? sometime i get a few beeping sounds. can someone confirm this? does this mean something is not hooked on correctly?
http://www.toyota-4runner.org/showth...2&pagenumber=2
http://www.norgetech.com/navsup.htm
http://www.toyota-4runner.org/showth...t=speed+sensor
I have spend two full days on this and still not able to get it going.
any help will be greatly appreciated
