Good idea for a reference even though some may prefer individual threads...but:
Tire Brand: Bridgestone
Tire Model: Dueler AT D684II
Mile Warranty: 5 yr / 60k miles
Your Mileage on/out of Tires: 55,000
Load Range: SL
Size You Chose: Stock 265/70R17
Dry Handling X/10: 7 when new
Wet Handling X/10: 4
Off Road X/10: 5
Ice Handling X/10:
edit: 2-3, not very good.
Comfort X/10: 8
Noise X/10: 7
Regular rotations? [Y/N]: Y
Would you recommend? [Y/N]: N
Additional Comments: These are OEM tires, 1st set went 55k almost to the wear bars but had started to squeal around almost every corner in dry conditions, traction was going away and they were badly showing their age. Got a 2nd set on a screaming deal while cash was short, and am regretting it. If you drive like grandma and never get into the wet these tires are ok. Wet conditions will find a lot of slipping in the turns
unless you are extremely smooth, and don't try to brake suddenly and turn into somewhere at the same time.
There are many much better tires out there at same or lower price point. Why in this day and age Bridgestone is selling a 360/B/B tire at almost $200 a pop is beyond me.
In all fairness they are quiet and do decently in snow up to about
edit 8" / 20cm, and in light offroading dirt/grass they were fine. With this vehicle I have nothing to compare, will return to the thread after I have the Coopers put on in a bit.
