Old 11-28-2020, 04:27 PM #1
04SR54me 04SR54me is offline
04SR54me is on a distinguished road
Frozen Bolt driving me mad
So, I'm installing new struts in my wife's highlander. I know, this is a 4runner forum, and I have one, but i need some help. The two lower bolts that mount through the steering knuckle...the lower one is frozen on 3 of the 4 wheels. The upper ones seems to be fine. Car has 190K and never had struts replaced.
I've tried PB blaster, WD 40, heating the nut with a propane torch, breaker bar and my ingersoll rand heavy duty 1/2" impact gun rated at 300 lbs torque.
How the heck do I get these things off. Any suggestions would be appreciated otherwise, its off to the repair shop and $$$.
Thanks!
04SR54me is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 06:21 PM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
Double post.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 06:25 PM #3
ads2539's Avatar
ads2539's Avatar
If they are nuts, you can try a nut splitter.
I didn’t have luck with a nut splitter on my rusty suspension, but I didn’t use a power tool, either. The nut splitter made a dent in the nuts, but didn’t split them.
I ended up using a grinding wheel to cut the frozen nuts off. It worked for me.
Old 11-28-2020, 11:37 PM #4
DMV4runner DMV4runner is offline
Real Name: William
DMV4runner is on a distinguished road
Real Name: William
Couple of things to try.
1. Keep spraying with the PB.
2. Get a ball pin hammer and a regular hammer. Put ball against bolt and tap flat side with other hammer. Hopefully the vibrations created will allow the PB to penetrate deeper.
3. Try to tighten the bolt. It might break the seal allowing you to loosen it.
Good luck.
Failure is written in pencil. "This sucks" builds character.
Embrace the suck
DMV4runner is offline   Reply With QuoteReply With Quote
Old 11-29-2020, 10:59 PM #5
Packpride85 Packpride85 is offline
Packpride85 is on a distinguished road
Good luck.
This except if you can get some Aero Kroil use that instead of PB Blaster. Plan B is grinder wheel to cut it off.
Packpride85 is offline   Reply With QuoteReply With Quote
Old 12-03-2020, 03:58 PM #6
3kushn's Avatar
3kushn 3kushn is offline
3kushn is on a distinguished road
3kushn's Avatar
Aero Kroil is really good stuff. Another great product is called Free All.
Both of these penetrate and attack corrosion.
Patience, spray, tap tap tap, heat, impact. Repeat
No WD40
3kushn is offline   Reply With QuoteReply With Quote
Old 12-12-2020, 12:19 PM #7
heat. use a propane or map gas torch or real acetylene torch & if its a nut heat the nut, if its a bolt heat the area the threads go in to... after a minute or so, use a impact gun or breaker bar & they should come loose. heat will expand the nut or boss around the threads & 1, break the rust//corrosion bond or 2, expand enough to free up the nut/bolt. have used heat literally hundreds of times on 30-40 year old cars rusted beyond belief & 9 out of 10 times it works great.
also some bolts have thread locker on them that requires heat to break free, no amount of penetrating oil will work if there is thread locker.
blaster , frozen , lower , nut , struts
HTML code is Off
need help with frozen exhaust bolt pokeyman 3rd gen T4Rs 9 05-13-2019 04:58 PM
Frozen alignment cam bolt HokieRunner 4th Gen T4Rs 40 06-16-2017 01:03 AM
HELP Sway bar end link bolt frozen and stripped buckeye4runner08 4th Gen T4Rs 8 07-11-2016 01:29 AM
Replaced frozen caliper, now a frozen "pin"? dwulffusa 4th Gen T4Rs 1 09-01-2013 06:47 PM
Power Steering Pump Pressure Hose Bolt--frozen Badbob Classic T4Rs 3 06-09-2012 07:31 PM
