Real Name: Joe
Real Name: Joe
Depending on the lift, a few more small things to look at:
1. Shim the driver's side with another 1/4" shim to even out the lean.
2. Take a look at the panhard bar in the back, make sure you don't have too much angle going on there. It can pull the rear end over to the side and effect the entire system.
3. Long shot, but check the installed springs and make sure they match. A higher weight spring may have made its way onto your truck by mistake.
4. Get all of your bushings checked. A worn bushing can effect the entire system as well. A bit harder to diagnose if a shop is not specifically looking for it.
Best of luck with your search for a solution. It can be frustrating (especially after 3 years!) But once you have found the culprit, it will make you love your rig again.
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, lift, step delete
