Old 03-25-2021, 05:24 PM #1
CO4x499 CO4x499 is offline
CO4x499 is on a distinguished road
Got a flat. Do I need to replace my other three tires?
2008 SR5 4WD. The tires are about 2 years old and have decent tread left. I got a flat and am not wanting to replace all 4 tires, especially since the other 3 have life left and I don't have $800 laying around. Additionally Cooper doesn't make the AT3 anymore. How bad for my car, diff, 4WD, etc, will it be to run a new tire with the other three used ones?
CO4x499 is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 06:07 PM #2
spartacus's Avatar
spartacus's Avatar
Assuming they can't fix the tire. Same size cooper with similar thead and youll be good. You can also put the tire in the front then rotate every 5k as usual.
Old 03-25-2021, 08:52 PM #3
21TOR 21TOR is offline
21TOR is on a distinguished road
If needed I usually change 2 at a time, new ones on the back. Tires usually run the tread off the front faster.
21TOR is offline   Reply With QuoteReply With Quote
Old 03-25-2021, 10:39 PM #4
Smitty19TRD Smitty19TRD is offline
Smitty19TRD will become famous soon enough
Same as above. Replace 2 and put new ones on the back.
Smitty19TRD is offline   Reply With QuoteReply With Quote
Old 07-31-2021, 06:32 AM #5
ilove2fix ilove2fix is offline
ilove2fix is on a distinguished road
I just patch them of i can and put it in the back if its in the front. Never had a patch fail in the many many times ive patched a tire. Unless its blown then replace both or if the other one is still in good shape find a used one in similar shape and put them in the back.
ilove2fix is offline   Reply With QuoteReply With Quote
4wd , flat , left , replace , tires
HTML code is Off
Driving with a flat-Replace or Good to Go? hogwild86 5th gen T4Rs 9 10-31-2019 02:42 PM
Got a flat! Want to start downsizing tires. Jester4kicks 4th Gen T4Rs 14 03-19-2017 07:37 PM
4Runner tires replace with Tundra tires Lineman Engines / Suspension / Wheels / Tires / Audio / Accessories 1 04-16-2016 01:22 PM
Four flat tires...at once! Snooperstyle 5th gen T4Rs 19 09-13-2010 02:36 PM
Fixing your own flat tires greasefingers 4th Gen T4Rs 35 12-17-2004 04:03 PM
