Old 04-24-2021, 05:10 PM #1
cdoyle's Avatar
cdoyle cdoyle is offline
cdoyle is on a distinguished road
cdoyle's Avatar
Correct wiring harness for a 2004 JBL non Nav
Hi,
Been trying to figure out which harness I need to update the stereo and not have to cut any wires.
2004 Limited, with JBL non nav
Behind the headunit I see 3 plugs.
I have a Metra 70-8114 which is supposed to be for the steering wheel controls.
Is this the correct one?
Which part #s do I need for the other ones? Metra's site listed a 70-1761 but that's totally not correct. Wrong size all together.
I believe I need a 70-8117, but before I spend any more money, is this the correct one?
Thanks!
Check out my 2004 4Runner Audio upgrade.
cdoyle is offline   Reply With QuoteReply With Quote
Old 04-25-2021, 10:07 AM #2
cdoyle's Avatar
cdoyle's Avatar
Anyone know?
Is the Metra 70-8117 the correct harness to buy?
Old 04-25-2021, 11:49 AM #3
JD914's Avatar
JD914 JD914 is offline
JD914 is on a distinguished road
JD914's Avatar
Check Crutchfield.com. They’re really good about adding on the correct accessories.
If you already own a head unit, you might need to load your vehicle and put a head unit in your cart for them to suggest the correct harness.
04 V8 Limited
Lifted, lit, locked, protected
Coffee machine and crock pot equipped
JD914 is offline   Reply With QuoteReply With Quote
Old 05-25-2021, 03:38 PM #4
Tha Krazy One Tha Krazy One is offline
Tha Krazy One is on a distinguished road
What you need with be the 70-8113, or could be you need an interface which would be the AXDI-TY1. It's an amplified harness. You might not have JBL but it means its still amplified, just not with the JBL Digital amp which would require the AXTO-TY1. The 70-1761 is for basic audio which you just mentioned is not it due to the harnesses not lining up. The 70-8117 is an amplifier bypass harness.
Tha Krazy One is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 06:52 PM #5
NCHornet NCHornet is offline
Real Name: Kevin
NCHornet is on a distinguished road
Real Name: Kevin
I have used Crutchfield's for this type of info. If you enter all your info it will tell you every adapter and trim kit required for a plug n play install. If that is where you got the incorrect harness number call them and they will look it up and verify the correct parts.
NCH
2007 Limited 4wd 140k
NCHornet is offline   Reply With QuoteReply With Quote
70-8117 , correct , harness , jbl , nav
HTML code is Off
Anyone have trouble finding correct radio wiring harness? LINY4Runner 3rd gen T4Rs 17 09-13-2021 04:30 PM
2004 V8 Throttle Body Position Sensor Wiring Harness 4thGen4.7 4th Gen T4Rs 0 05-10-2020 04:37 PM
Wiring air on board switch to Amazon wiring harness. Btmannin Engines / Suspension / Wheels / Tires / Audio / Accessories 3 06-18-2018 03:33 PM
Single DIN stereo: correct storage bin and wiring harness? dbsoundman 3rd gen T4Rs 2 11-14-2012 11:33 PM
Help with locating correct wire harness adapter propman07 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 08-17-2009 11:45 AM
