Old 05-31-2021, 02:17 PM #1
oltombon's Avatar
oltombon oltombon is offline
oltombon is on a distinguished road
oltombon's Avatar
Tire Research Vomit
I've about driven myself mad researching tires the last two weeks. I'm down to 4 tires. Dumping this here partly to organize my own thoughts, partly to see if anyone has any takes. All info is based on a 265/70/17 tire.
This tire is going on my '20 TRD Offroad. Leaning towards a more aggressive all-terrain because I only put about 7-8k miles a year on this vehicle. Not a commuter, but still do the majority of the miles on pavement.
Did discount's rating system (Good, Better, Best):
Yokohama Geolandar X-AT (E)
Price: $227
Style: Better
Height: Best (32")
Weight: Good (56lbs)
Rep: Better
I like it because it's the tallest of the stock sized tires. Also probably my second favorite looking design.
BFG KO2 (E)
Price: $230
Style: Best
Height: Good (31.6")
Weight: Better (54lbs)
Rep: Better
The best looking all-terrain. Nothing else about it seems to stand out though.
Toyo Open Country AT3 (E)
Price: $230
Style: Better
Weight: Best (49lbs)
Rep: Better
The 2nd or 3rd best looking, and the lightest.
Falken Wildpeak AT3 (E)
Price: $246
Style: Good
Weight: Better (53lbs)
Rep: Best
The Falken is not my favorite but probably the most well-recommended of the 4 on forums. The worst looking of the 4 to me.
oltombon is offline   Reply With QuoteReply With Quote
Old 05-31-2021, 02:40 PM #2
armabill armabill is offline
armabill is on a distinguished road
I was looking at the Grabber A/TX.
armabill is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 02:39 AM #3
Its GSatt Its GSatt is offline
Its GSatt is on a distinguished road
My two cents, don’t get conservative if you want a good looking tire. Get the right size to get a stance you want. 265/70-17 probably not it. You can get the “best looking” tire, but if it’s too small, you’ll have remorse. Find the size. I’m in the 3rd Gen and that size looks beef on this, but your rig will swallow that . I think there’s a 275/70-17 if I recall on my research for my tires. Not the most popular, but someone makes it and it should be a 33”. I think BFG. More importantly, a little wider. Makes a big difference if you staying close to stock.
Good luck, I spent months calculating what tire. It influences where you might end up with a lift etc. etc. and one thing leads to another….
Its GSatt is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 08:46 AM #4
Old Tanker Old Tanker is offline
Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about Old Tanker has a spectacular aura about
Don't be overly conservative, sure. But also make sure that the tire fits - you should be able to jack it all the way to the bump stop and go from full turn to full turn without anything rubbing.
Old Tanker is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 12:17 PM #5
oltombon's Avatar
oltombon's Avatar
Yeah, I’m with you here. One thing I didn’t mention is that I don’t intend to lift this vehicle. I looked at 275/70s initially but 1) limited choices and 2) don’t want rub.
I think this is why I’m leaning towards the Yokohama. At 32”, it’s the biggest 265/70 I could find and close to a lot of AT offerings in 275/70. Plus it looks good and Yokohama makes a good tire afaik.
Old 06-01-2021, 12:26 PM #6
Swipter Swipter is offline
Swipter will become famous soon enough Swipter will become famous soon enough
My intention was to not lift and go with yoko at x but the weight was a little much for me. I really don't off road but I wanted the stance.
I went with toyo atiii p285 70r17 tires with fn wheels and a 3 inch lift. The total weight is one pound less than stock tires and wheels. My mpg is unchanged for combined driving and they track and ride great.
I also drive very little, annually, and 14k on my 3-year old sr5. My wife now likes my 4runner better than hers and wants the same done to get Limited 4runner.
I totally agree with above that 265 is not it. Do it once and do it right and you'll be happy.
Swipter is offline   Reply With QuoteReply With Quote
Old 06-01-2021, 01:35 PM #7
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Yeah, looking into tires can drive one nuts.
You are missing my current tire, which is the Mickey Thompson ATZ P3.
Your tires belong to two sub-categories:
Lighter duty for the Toyo and Falken and heavier duty for the ATZ P3, the X-AT, and the KO2.
Of the latter, the KO2 is easy for me to discard.
So that leaves the ATZ P3 vs the X-AT.
They have the same full 32" height and seem to have the same weight. Both have a 3-ply sidewall. Both should do better in mud than anything else on your list.
I can say that the ATZ P3 has surprised me for how civilized it has been on road, at least on stiffer suspension. I don't think any E load will play nice with the soft stock suspension but I can be wrong
Off-road, it offers total peace of mind and does great at 21 psi. Short of deep sand and the like, it can do just fine at 28 as well, just less comfort over rocks.
I am not sure I have a strong opinion about ATZ P3 vs X-AT.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 06-01-2021, 01:52 PM #8
Ripper238's Avatar
Ripper238's Avatar
Curious, why not Duratracs and why an extra heavy E load?
Old 06-01-2021, 04:14 PM #9
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Have you considered anything other than an E load? It will open up some options. Personally I dislike how an E load feels... I usually stick to C and D load at most.
If you only put low mileage and actually use the truck off-road, I would get a mud-terrain. I absolutely love how well they do off-road.
I know... not making it any easier lol
Old 06-01-2021, 05:15 PM #10
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
Where are you driving? Different places have different demands.
I live in the southwest desert.
Ambient temperatures can reach 120°+. Offroading is sharp rocks and ledges. Wet and snow traction is less of a priority (it does snow here too)
I've been researching tires for the eventual replacement. My choice for me is the Toyo Open Country A/T III. But I see every make and model on vehicles around here.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 06-02-2021, 11:15 AM #11
oltombon's Avatar
oltombon's Avatar
Thanks for this post - you made me re-think everything haha. Not sure why I hadn't considered the Duratrac - but I researched it, and due to another comment I read, also decided on getting 255/75/17s...which the duratrac is offered in! I'm about to pull the trigger on a set of SL Duratracs in that size since discount tire is doing a sale on them right now. Appreciate you!
Old 06-02-2021, 12:11 PM #12
ToyotaWorldRunners ToyotaWorldRunners is offline
Real Name: Matthew
ToyotaWorldRunners is on a distinguished road
Real Name: Matthew
I've ran the duratracs in a 31" and a 33" on a few different rigs and really like their overall performance. I also think they are one of (if not the most) aggressive and good looking all terrain tire. Every tire has it's downsides, but I would vote for the duratracs or the geolander.
ToyotaWorldRunners is offline   Reply With QuoteReply With Quote
Old 06-04-2021, 12:51 PM #13
oltombon's Avatar
oltombon's Avatar
Decision finally made.
Ordered a set of Yokohama Geolandar M/Ts in 255/75/17 from discount. Have an appt next Wednesday to get them put on. Will post a pic.
Old 06-09-2021, 05:12 PM #14
Ripper238's Avatar
Ripper238's Avatar
Interesting choice. Definitely let us know how they are. Curious how they are in the rain. Did u go with a C load?
Old 06-09-2021, 09:39 PM #15
whyzee125 whyzee125 is offline
whyzee125 is on a distinguished road
I've had a lot of A/T's and IMO, Toyo ATII and AT3 are by far my favorites. I wouldn't hesitate to go Toyo with the options listed here. You won't regret it.
Originally Posted by LittleCaesar View Post
At 5'7", I'd need a rocket up the wazoo to get in it.
But it looks good. I can't wait to see it being driven.
whyzee125 is offline   Reply With QuoteReply With Quote
good , height , price , style , weight
HTML code is Off
Best way to research VIN Crammit442 3rd gen T4Rs 6 06-13-2018 02:57 PM
33 inch tire weight research for you dieck Engines / Suspension / Wheels / Tires / Audio / Accessories 1 05-12-2015 02:51 PM
AMP Research Powersteps arvmark 5th gen T4Rs 5 03-27-2015 08:28 AM
2wd to 4wd conversion research GoldTaco 3rd gen T4Rs 1 10-22-2014 09:44 PM
Marketing Research stlfan General Discussions 7 11-15-2011 09:03 PM
