Old 06-03-2021, 07:32 PM #1
NCHornet NCHornet is offline
Real Name: Kevin
NCHornet is on a distinguished road
Real Name: Kevin
2007 Limited 18" to 17" & Needing Different TPMS's True or False?
What a mess this has turned to and decided I needed to ask those who know about these more than the tire shop flunky I was talking to today.
OK, first time 4runner owner as of 6 days ago. Picked up a very clean 07 Limited 4.0 V6 4x4 with 140K on it. It has highway tires which won't work for my needs so I began looking for new tires and came across a set of 17" Toyota 4Runner wheels in like new condition for a great price so I bought them. I was a bit surprised when I learned the Limited came with 18" and the other models came with 17" back in 07. Can't say I recall seeing wheel size changing by model like that but figured it wouldn't be an issue. Stopped by the local tire shop to see what some BFG AT's would run in the 17" size.
Next thing I know I am being told the 17" wheels won't work on my Limited because the 17" are not only smaller but they are an 1/2" wider than the 18" wheels and this would cause severe rubbing issues. He went on to say that switching over the TPMS sensors wasn't possible because the 17" wheels used a different TPMS sensor that has a different angle and set to a different psi and wheel diameter than the 18" Limited wheels.
Who would have thought I would run into all this just by going down in wheel size? I bought the 4Runner from the original owner who told me that the TPMS sensors had never been changed as far as he knew and he handed me a pile of receipts for everything that had ever been done to it and I didn't see in any of those receipts. There was no light on in the dash for the 2 hour drive home but a couple days later had a solid TPMS light come on but a few lbs of air in the spare made it go away. Coming back from a long road trip this morning brought up a flashing TPMS light so it's probably a weak battery in one or all of the sensors.
So my question is, am I really going to have a rubbing issue going with the smaller 17" 4Runner Wheels? Next is are the TPMS sensors different for the 18" and the 17" wheels? I had always planned on installing new TPMS sensors when I have the new tires mounted on the 17" wheels and I will be installing them myself as a buddy of mine has a shop with the mounting and balance machines, I just want to be sure I buy the right sensors the first time.
Is there an aftermarket brand that is preferred for the 4Runner or is it best to stick with OEM? Thanks for the advice and info and I look forward to learning more about these 4Runners. Hope y'all have a great day.
NCH
2007 Limited 4wd 140k
NCHornet is offline   Reply With QuoteReply With Quote
Old 06-07-2021, 08:53 PM #2
Real Name: Kevin
Real Name: Kevin
Anyone? Tried search again but nothing found about different sensors or any issues going from Limited 18" to 17" standard. Thanks
NCH
Old 06-08-2021, 12:07 AM #3
dontek dontek is offline
dontek is on a distinguished road
For what it's worth, digging around in the parts catalog at Stevinson Toyota, I find 2 TPMS parts listed that are compatible with 2006-2009 SR-5, Sport & Limited:
4260733012
4260733022
That seems to suggest maybe wheel size doesn't matter..? (not sure what the difference is, but it doesn't appear to be stem profile from the photos)
However, I do see OEM Replacements at Rock Auto, some with straight stems (Denso) and some with angled stems (Schrader).
As far as the pressure goes, I'd guess that's set during the relearn procedure..?
2006 SR5 4WD V8 4Runner - just starting the build
dontek is offline   Reply With QuoteReply With Quote
Old 06-08-2021, 06:56 PM #4
Real Name: Kevin
Real Name: Kevin
Thanks for looking into it for me.
NCH
4runner , limited , sensors , tpms , wheels
HTML code is Off
Is it true that leaving your headlight setting on "Auto" will damge your HID? Ixz72 5th gen T4Rs 17 12-15-2017 03:04 PM
5th Gen "Premium Security System" - False Alarms? (Check Interior Lights!) Randyman... 5th gen T4Rs 9 10-01-2014 02:42 PM
2007 4Runner Limited 18"x7.5" wheel question scw1991 4th Gen T4Rs 5 12-26-2013 06:54 PM
2007 Toyota Sequoia "Limited" Factory 17" Wheels/Tires TRD98TT For Sale: Suspension/Wheels/Tires 9 03-17-2013 09:01 PM
"true" dual exshust (header back) any one? RXvedub Engines / Suspension / Wheels / Tires / Audio / Accessories 9 06-13-2005 09:15 AM
