Old 06-18-2021, 12:12 PM #1
Ripper238's Avatar
Ripper238's Avatar
Time Delay on Relay for AMP?
I have an aftermarket DSP and AMP and i am getting an initial pop at startup. I need a ~10 second delay for the AMP to turn on but i am having a hard time finding a reliable easy device to provide this delay.
I have tried 2 different Pac TR7's and another time delay with no luck. These things suck to program and so far they never work.
Any simple solutions? suggestions?
Old 06-18-2021, 12:36 PM #2
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
What you want is a "on delay timer relay"
They are common in industrial controls. I use ones branded by ABB, but you can find inexpensive ones all of the place.
You can wire the output to the amps remote turn on wire. So after a set amount of time, it will turn on.
GAEYAELE GRT8-A2 Delay On Time Relay Electronic 16A AC/DC12-240V with CE Certificate GRT8-A2 AC/DC12V-240V - - Amazon.com
Old 06-18-2021, 01:01 PM #3
Ripper238's Avatar
Ripper238's Avatar
Yes, using this on the amps remote turn on.
Looks like its overbuilt and used for AC but its rated for DC 12v too so looks like it will work perfect.
Old 06-18-2021, 03:03 PM #4
Bumbo's Avatar
Bumbo's Avatar
My link is just an example... I've never used that brand. DC only units exist as well.
I typically use more brand name stuff like ABB, but it's a lot more expensive. eBay is a great place for used brand name stuff like this.
If you need to switch larger loads, you can pair these with relays or contactors, but amp remote signaling is fine though the timer relay.
Old 06-19-2021, 10:31 AM #5
Ripper238's Avatar
Ripper238's Avatar
Thank you!
With all the trouble i have had trying to get a simple on delay timer for around 10sec that actually works ill do/try just about anything.
Ill look for ABB but it appears the only ones i have found are from far away country's. lol Im not a big eBay user.
amp , delay , pac , time , tr7
HTML code is Off
Sprint Booster SALE for 4th gen 4Runner, Limited time. Reduces delay of drive by wire Jason B 4th Gen T4Rs 311 08-18-2023 04:17 PM
Relay Pin-out diagram needed - relay part no. 90987-02012 HiluxSurf SSR-G 3rd gen T4Rs 2 07-01-2020 04:54 PM
Changing the lights-off time delay in the cargo area Lewis&Clark 4th Gen T4Rs 1 02-18-2016 11:39 AM
time delay for engaging 4x4 leedogg Off-Roading 6 03-27-2008 06:26 PM
