Old 06-10-2021, 11:14 AM #1
jondoe1482's Avatar
jondoe1482 jondoe1482 is offline
jondoe1482 is on a distinguished road
jondoe1482's Avatar
Tire inflation pressures
I just did the chalk test on my 5th gen 4Runner with nitto Ridge grapplers 255/80R17, new tires, load range E. I have all tires inflated to 32 PSI cold pressure. The chalk test on the front tires showed perfect even wear across the tread. The chalk test on the back tire showed more wear in the center of both rear tires as opposed to the outside. This inflation pressure is the recommended inflation pressure for the stock vehicle, but I've added extra weight and I have changed the tires to load range e versus a passenger tire. I don't really want to reduce the pressure more than that, but the chalk test results suggest I should reduce it in the back tires. I assume this is because of the higher weight on the front end versus the rear despite having cargo in the rear at the time of the test. Additionally, it seems in most vehicles that the pressure is recommended to either be the same all the way around or increased in the rear tires and comparison to the front tires if there is extra cargo. Again, this test was done with a moderate amount of cargo in the rear. What would y'all advise?
Sent from my Pixel 4a using Tapatalk
2016 Toyota 4Runner TRD Pro Quicksand - Gobi Stealth Rack & ladder - OPOR/Metaltech TRD Pro Rock Sliders - Custom Cargo Track Bin Storage on Sliding Rear Deck - Scosche Phone Mount - 3" Lift from Radflo 2.5" Coilovers 700 lb Springs w Remote Reservoirs front & 2.5" Radflo in back w Toytec 2" RCC2.0 rear Springs - High clearance bumper cut - Warn Semi Hidden Winch Mount - Warn VR Evo 10-S - Factor 55 Flatlink Expert w Rope Guard - 255/80r17 Nitto Ridge Grapplers
jondoe1482 is offline   Reply With QuoteReply With Quote
Old 06-12-2021, 08:24 AM #2
<<<<'s Avatar
<<<< <<<< is offline
<<<< is a jewel in the rough <<<< is a jewel in the rough <<<< is a jewel in the rough
<<<<'s Avatar
32 PSI is safe enough and with tall aspect ratio you don't want to run low pressure or that back end will move around too much especially while towing. Just rotate them as recommended and it'll be all right.
TRD 17x8.5 Wheels / Nitto RG 285/70/17 / Shrockworks Sliders / ASFIR Al Trans Skid / B&I CF Dash / TRD Stealth Shift / LED Floor Ambient Light / Prado Al Pedals / Ellis Precision Al Battery Holddown / Northstar AGM Battery/LED interior / ARB on-board Air / LC custom Engine Cover / CF GC Shelf / Fire Ext & MagLite
<<<< is offline   Reply With QuoteReply With Quote
Old 06-12-2021, 10:19 AM #3
Ripper238's Avatar
Ripper238 has a spectacular aura about Ripper238 has a spectacular aura about
Ripper238's Avatar
You definitely jumped down a huge rabbit hole with E rated tires. lol Thats why i went with C rated tires and even that was annoying with air pressure, but at least i could run a wide range of air pressure to meet my needs.
If you are proactive in your weight calculations per tire you can modify your air pressure accordingly. I also wouldn't 100% rely on the chalk test, rotate often and that recommended inflation on the door is now meaningless with E rated tires and the new load index of the tire. What's your load index?
This is what i did to make sure i met the important points.
I went with C 112Q rated Duratracs.
4R RGAWR (rear) = 3439 lbs /2 = 1720 lbs (no load) per tire and since 112 load index = 2469ea at 50psi i can run the C 112Q rated Duratracs at ~38+ psi and exceed the actual RGAWR still. If i need additional weight capacity i just bump up the air pressure up to 50 and get the full 2469 at max capacity of each tire exceeding the stock required load index.
Old 06-16-2021, 03:50 AM #4
truc.karl truc.karl is offline
truc.karl is on a distinguished road
I would put 32-35 psi for that tire size.
truc.karl is offline   Reply With QuoteReply With Quote
chalk , pressure , rear , test , tires
HTML code is Off
OffRoad tire Pressures TheWraith 5th gen T4Rs 49 03-04-2021 04:07 AM
E rated tire pressures Derek G General Discussions 21 08-15-2020 09:40 PM
How low do you go? 5th Gen Off Road Tire Pressures Canazes9 5th gen T4Rs 12 12-16-2013 03:41 PM
Winter Tire recommended inflation pressures Batang.Gapo 5th gen T4Rs 0 09-05-2011 07:41 AM
What tire pressures for best gas mileage? neocacher 4th Gen T4Rs 13 05-30-2011 09:50 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
