Old 07-22-2021, 07:42 PM #1
702_SR5 702_SR5 is offline
702_SR5 is on a distinguished road
Bedding down operation for parking ("emergency") brake?
Looks like I'll be getting a new 2021 4Runner soon.
So I was perusing the "Breaking in your new Toyota" section of the manual. Most of it looks pretty standard, but this caught my eye:
Of particular interest: "...needs bedding-down of the brake shoes periodically."
What is the procedure, and how often should it be done?
702_SR5 is offline   Reply With QuoteReply With Quote
Old 07-24-2021, 08:51 AM #2
riceandpho's Avatar
riceandpho riceandpho is online now
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
i guess empty road, go up to a certain speed, maybe not more than 15-25 mph, instead of using regular brake, use the parking brake to slow down, just dont smash on the parking brake pedal hard, i guess just ease into it. either your suppose to ease into it, or smash on it.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is online now   Reply With QuoteReply With Quote
Old 07-24-2021, 03:49 PM #3
NCHornet NCHornet is offline
Real Name: Kevin
NCHornet is on a distinguished road
Real Name: Kevin
I think the above is probably correct, however I fail to see why this should need to be done periodically? The only time this should be required is after new pads are installed or if the drum is turned on a brake lathe. It's no different than braking in a new set of brake pads or shoes. It's not so much needed on the good old semi metallic pads as it is on the newer, much harder pads of ceramic and other very hard pad materials.
The way this is done is to hit 10 to 15 mph and apply the brakes and bring the vehicle to almost a full stop and then increase once again to 10 to 15 mph and repeat 3 times. Next you go through the same process but with speeds of 25 to 30 mph. At these speeds you apply the brakes a little harder than you did before but not letting the vehicle come to a complete stop. once you have done this 3 times you repeat the process one more time with speeds of 55 to 60 mph and each time to apply the brakes your using slightly more pressure than you did the previous time but not letting the vehicle come to a complete stop.
After completing this procedure the idea that the pad is making full contact with the braking surface which is a rotor or drum. I'm not saying the process is exactly the same for the E Brake as the pads are smaller and an E Brake isn't used to bring the vehicle to a complete stop, it is simply to keep it from moving once it is at a full stop. But I am assuming the procedure would be similar to this with speeds and number of times repeated being less.
NCH
2007 Limited 4wd 140k
NCHornet is offline   Reply With QuoteReply With Quote
bedding , brake , caught , eye , interest
HTML code is Off
Emergency parking brake noise rwh963 4th Gen T4Rs 4 04-09-2021 08:50 AM
Parking/Emergency brake adjustment help Ph3n0m427 5th gen T4Rs 21 01-13-2020 09:11 PM
Parking Brake / Emergency Brake Question Woz1976-MT 5th gen T4Rs 5 04-21-2018 05:52 PM
Parking brake: Feels "On" and handle is loose OnTheEllipse 3rd gen T4Rs 6 09-26-2013 04:08 AM
