Old 08-10-2021, 12:11 PM #1
ilove2fix ilove2fix is offline
ilove2fix is on a distinguished road
2.7L Toyota 2TR-FE engine poor mpg. No lights . What can i check ?
Hi guys i have a tacoma with v4 2.7L engine 2TR-FE
No lights , but. Getting bad mpg and sometimes loss of power. Old owner did bore out the first catalytic converter and i think the 2nd one right behind it is semi bored out. Thats what a mechanic told me when he took out the whole setup. He said it wont cause power loss if anything itll give more power but louder , which it is much louder. But im worried about the mpgs. I did notice tires little low like 30psi would that cause bad mpgs ?
ilove2fix is offline   Reply With QuoteReply With Quote
Old 08-10-2021, 02:53 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss is a glorious beacon of light rdruss is a glorious beacon of light rdruss is a glorious beacon of light rdruss is a glorious beacon of light rdruss is a glorious beacon of light rdruss is a glorious beacon of light
rdruss's Avatar
Real Name: Ron
I'm game! What's a 2.7L V4, a 4.0 with two spark plugs pulled?
Old 10-01-2021, 08:20 AM #3
Jakeepoo3's Avatar
Jakeepoo3 Jakeepoo3 is offline
Jakeepoo3 has a spectacular aura about Jakeepoo3 has a spectacular aura about
Jakeepoo3's Avatar
You need an air fuel ratio tune. Anytime you modify the way the truck breathes and exhales. Yes you will have more power and torque after proper tune. Before you do that I would just remover the cats completely and straight pipe them.
Jakeepoo3 is offline   Reply With QuoteReply With Quote
Old 08-15-2022, 06:30 AM #4
John Simon John Simon is offline
Real Name: John Simon
John Simon is on a distinguished road
Post Bad gas milage
things that causes bad milage,
i) Low Tire Pressure.
ii) Bad/worn-out spark plugs.
iii) Jammed brake pads.
iv) Bad Oxygen Sensors and/or Air Filters.
v) Driving Habits.
vi)Bad Fuel Injectors.
vii) Air Conditioner.
viii) Motor Oil.
ix) Idling.
John Simon is offline   Reply With QuoteReply With Quote
bad , loss , louder , mpgs , power
HTML code is Off
05 Traction lights & check engine lights on Ginneta 4th Gen T4Rs 16 02-27-2022 09:19 PM
What would cause 07 Toyota 4Runner 2WD SR5 check engine + VSC TRAC lights to come on? jow 4th Gen T4Rs 14 10-02-2021 12:38 AM
Check Engine Light, VSC OFF And Check VSC Lights just came on??? the_josh Maintenance/Detailing 5 07-15-2019 01:25 PM
'check engine', 'trac off', and 'vsc' lights came on. Plus 'abs' and 'brake' lights thehadley4 3rd gen T4Rs 0 10-23-2011 01:51 PM
Check Engine & VSC Lights Come on; now off Mtneer001 4th Gen T4Rs 5 11-12-2007 11:43 AM
