Old 11-08-2021, 04:59 PM #1
KRose KRose is offline
KRose is on a distinguished road
Question Testing ARB air lockers and 4wheel drive functionality before a trip
If 4wheel drive has not been used for a while is there a common way to test air lockers for functionality before going off road? For 4wheel drive is there a better method to test if 4low is working than seeing if it binds up on pavement. Thank you.
KRose is offline   Reply With QuoteReply With Quote
Old 11-08-2021, 06:57 PM #2
spartacus's Avatar
spartacus's Avatar
What Gen 4runner. You can engage 4hi 4lo in a straight line. If all the lights on the cluster engage like normally, there is a good chance your system is working properly. when the front is locked it is hard to turn yout can feel the bind. To check the arb, raise one rear tire, engage the arb, chalk the other tires. put it neutral. If the raised tire spins then it's not locked.
Old 11-08-2021, 07:13 PM #3
5th gen. 4 lo feels like it has extra pulling power if that makes sense. I will test the locker in the way your mentioned. Thank you for your help.
4wheel , drive , functionality , lockers , test
HTML code is Off
Lockers on the V8 Full Time 4Wheel Drive Desert Fox 4th Gen T4Rs 33 12-23-2019 06:56 PM
Quadra Drive II vs 4runner 4wheel drive system. JosephD05 Comparisons & Reviews 3 09-25-2013 10:11 PM
4wheel drive plumr 4th Gen T4Rs 17 04-13-2011 10:17 AM
How often do you use 4Wheel Drive? Wanderer 4th Gen T4Rs 36 05-12-2010 04:19 PM
wont go into 4wheel drive spdsmoky Classic T4Rs 6 08-27-2008 11:45 PM
