04-26-2004, 08:24 AM
#16
Cant wait to see pics of the final project.
2004 Toyota 4Runner V8 Sports, Galactic Grey Mica, Amsoil Air Filter, Scion xB radio
Friends don't let friends drive Jeeps!!
04-26-2004, 10:21 AM
#17
Karputer ?
The good:
Take a peek here at
http://www.karputer.co.uk/karputer.php?page=product
The bad: It's manufactured in the UK
The ugly:
The price is a whopping 1750 GPB (UK Pounds) or roughly $3,124 USD.
Black 2003 SR5 V6 4WD (Option Pkg C) ClearBra, painted pinstripes Mods: Rear glass limo tinted/ fronts 27%, Sunroof Deflector, Auto Dimming Mirror, VVT-i emblem, Homelink, Valor Tip -- Aftermarket: Weathertech Deflector, AVS Ventvisors & Tailshade tail light blackouts, Silver Star bulbs, 7.2" Widescreen TV/DVD, PNI Wayfinder Compass, K&N Air Filter (Part #33-2281), Husky Cargo Liner, Wood Trim Kit, Third Brake Light Flasher, Amber Whelen Slimlighter (aux. rear hazard warning) Rear foglamp housings modifed for aux. tail/brake/signals/hazard (See Rear Fog Mod Thread here : http://www.toyota-4runner.org/showth...threadid=1137)
04-26-2004, 11:24 AM
#18
Re: Karputer ?
That's pretty funny. Those are the same components (Lilliput LCD, and Casetronic C134 case) I am using. I even have that keyboard (made by Zippy) though I bought the unlighted version by mistake. No big deal though since once the system is working, I shouldn't need to use the keyboard except for maintenance.
See above for a price breakdown. It will be well below $3124.
'04 SR5 4x4 V8 Titanium/Stone - 2/1/04
Mods: Homelink+x10, RS3200+, Auto Headlights, Compass Mirror, CarPC, DRL, PDF Manuals, Auto Map Lights, MGCLT Relay Saver
Future Mods: 115V Inverter, Leather, Trip Computer Fix
04-26-2004, 11:29 AM
#19
Me too ... unfortunately, it's going to take a while.
05-02-2004, 11:58 AM
#20
This is the Casetronic C134. It holds the motherboard and laptop hard disk. The mouse is there only to give you an indication of the size of the computer. The mouse is not used in the final system.
The slot in the front can hold a laptop size dvd/cd drive.
05-02-2004, 12:00 PM
#21
Here is the back of the case.
05-02-2004, 12:02 PM
#22
The top of the case with the DC-DC power supply, GPS, and Zippy keyboard.
05-02-2004, 12:04 PM
#23
Modified LCD Case. I had to chop the front top, notch the back top, chop the bottom front, and chop and notch the bottom back.
Strips of MDF are glued to the side to fill out the dash opening. Bondo and paint will be applied to give a smooth finish.
05-02-2004, 12:05 PM
#24
How it fits (backside). Only tiny modifications were required to the backside center console itself.
05-02-2004, 12:06 PM
#25
Dash install (front).
05-02-2004, 02:58 PM
#26
Bondo and sanding ... pass #1.
05-02-2004, 06:33 PM
#27
Second coat of Bondo plus sanding. 7 Coats of black trim spray paint with #0000 steel wool between coats. LCD installed to test fit.
05-02-2004, 08:04 PM
#28
Dry Run!
05-02-2004, 08:35 PM
#29
that is SWEET! lookin GOOD!
2002 Sport Edition
Thundercloud Metallic
'94 sr5 v6 extra cab
Pewter Pearl Metallic
05-02-2004, 11:53 PM
#30
Lookin' good! I'm looking forward to seeing more.
-Jason
'04 galactic gray Limited V8 4x4 with X-reas--and yes, it does look a lot like yours except for the mods.
HTML code is Off
