Old 09-15-2021, 12:40 AM #1
kaitlyn2004 kaitlyn2004 is offline
kaitlyn2004 will become famous soon enough
Clarification on lift kit "adjustability"
I'm still on my stock 4Runner TRD Offroad, but have always been looking into lift options. I see various terms for what some suspension options offer, and I wanted to know about adjustability.
When something is i.e. adjustable 1-2" lift, is that sort of something I can change day-to-day, month-to-month? Or do you basically have to bring it into a shop and changing effective lift is not "easy" once set?
Similarly, I've seen some mention being able to adjust the behavior of the dampening (and some the rebound too?). Are these also easily adjustable? I drive 95% on paved roads, and so I (think?) I like the idea of being able to set a more stiff ride for comfortable driving, but then adjust it for when I go offroad or on "overland" trips, etc.?
In a nutshell, I'm having some trouble understanding some of these options, and at the same time am clearly novice when it comes to all this - I want to lift my 4runner but, ideally, improve BOTH onroad and offroad performance.
kaitlyn2004 is offline   Reply With QuoteReply With Quote
Old 09-15-2021, 10:33 AM #2
ads2539's Avatar
ads2539 ads2539 is offline
Real Name: Howard J. Turkstra
ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough ads2539 is a jewel in the rough
ads2539's Avatar
If you are handy, you could adjust the suspension height yourself, but it is not as simple as turning a knob. You would need a spring compressor for the front coilovers, or do the “no spring compressor” method that’s explained elsewhere on this forum. It is a time consuming process either way.
As far as adjustability, very high end shocks are adjustable for compression and rebound. It is a simple thing to do. The hard part is figuring out the settings you want.
2004 Limited V8 4WD 183k miles. Stratosphere Mica paint, Stone interior. Too many mods to list here.
ads2539 is offline   Reply With QuoteReply With Quote
Old 09-16-2021, 09:29 AM #3
southern_runner southern_runner is offline
southern_runner is on a distinguished road
hey Kaitlyn,
Unless you have an "active" suspension that is adjustable from the truck, the suspension components that are advertised as adjustable are not done so easily. It's more of a "pick a setting" and leave it type deal.
I am going with an Ironman 4x4 kit, and they have options for the suspension stiffness. For example, I'm doing a 3" lift in the front and choosing "Performance mode" which is their standard spring. However they offer a "constant load" spring that is advertised as carrying 110-220lbs additional weight. You might choose that if you towed almost all the time or had a lot of extra weight from accessories on your Runner, but otherwise the Performance spring gives a better ride under normal conditions, which is what most of us do 95% of the time.
southern_runner is offline   Reply With QuoteReply With Quote
Old 09-24-2021, 06:42 PM #4
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
Considering what you say here, probably Bilstein 6112 with your choice of rear shocks is the best way to start. Tons of gain for minimum cost. You can then proceed to pricier setups as desired.
The 6112 on standard springs will improve on road performance and comfort tremendously. Off-road it will last longer than stock but you won't be able to drive much faster than stock. In rocks, it will feel similar. Using the same shocks on the stiffer springs improves offroad performance a great deal at the expense of losing the plush ride on road. But still very good.
As Southern_Runner said, it is more of a pick and leave it deal anyway when it comes to adjustments.
If you have kids, then the rear shock matters. If not, just a simple 5100 will do for a start or an Eibach rear shock. They are very cheap so if they are not enough you can keep them as spares and move up the ladder from there.
If you do have kids AND also do lots of offroading over harsh terrain, then there is no cheap option for the rear. The Dobs MRA rear would be an interesting option though I never tried it and went straight for the best instead. Again, this is only worth it if doing lots of offroading at some speed over harsh terrain.
(6112s/650lb at 1.25"-1.5" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
adjustability , adjustable , lift , offroad , options
HTML code is Off
3rd Gen 3" Lift (5100 Clarification) Drifter2080 3rd gen T4Rs 12 07-07-2020 03:14 PM
3" Cornfed Lift Nitto Terra's & MB Motoring V Drive Wheels "Pics" husky62 4th Gen T4Rs 35 03-25-2010 11:28 AM
" Toyota taking 1 for the team" clarification shawnstcyr General Discussions 9 07-26-2009 12:32 AM
First "Pre4runner" w/4" Lift Spinle Prototypes by Allied Motorsports Bala de Plata Off-Roading 26 03-01-2007 01:35 AM
