if you have a new aftermarket radio installed, i would put a good nice 6 or 8 channel in there, the class d amps are small, but it will cause some radio interference.
if you can take out each speaker to test, making sure the speakers are good, then the amp is the problem. remember under the front seats have enough space to put a decent size amp.
i run multiple amps since i can upgrade the power later on.
also if you used those amp integration, make sure the wires are not pinched or grounded by accident.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
