So I have a new to me 2012 SR5. I didnt care for the stock wheels so I found a set of TRD's the same size as mine. The new set came off a 2020 4r venture. Tires and TPMS sensors were installed from the factory - stock set. I was able to get the TPMS ID's from the new tires and load them into the ECU via a Autel TS508 scanner through the ODB2 port. I have confirmed they are stored in the ECU. However the TPMS light flashes then stays on everytime. Its been about 2 days and the light still wont go off. Thought maybe it needed to learn or something.
So i thouhgt maybe it is was the 315Mhz vs 433Mhz of the sensors themselves but it appears the 2020 uses the 315Mhz which I'm pretty sure the 12' SR5 did as well.
Now I wonder if it has to do anything with the TPMS recevier?
I'm at a loss here.
