I have the 07 JBL 6-disc headunit. Does anyone know of a solution to run the factory xm radio and and ipod/aux-in at the same time? I was reading the pac aux-in adapter, but it says it does not work with satellite radio, it must be either or.
I really want to keep the factory satellite because i like the clean look without the extra device. Any input would be great. Thanks.
Awesome. That's great information. I'm looking at the SLX. Is the XM kit from Toyota the same as the Terk XM? The website does not indicate if it supports the factory XM setup.
Look at the application guide for vehicle and see what emulation mode it uses. If yours uses SAT mode then it will be just like using factory XM.
However....if you already have factory XM I still think you can just add one of their Aux interfaces for it. I also checked PACs website and they have another ipod interface specifically for toyota that doesn't mention anything about xm, dvd or anything else effecting the install. Its the AUXBOX2 or something like that.
TPnNC
[ 00' Limited ][ JL 12w7 ][ JL 500/1 ][ DDX-8019 ][ NAV & BLUETOOTH ]
