09-18-2007, 11:44 AM
Larger sized tires and Toyota Tire monitoring system
For anyone using a 265/70R17 on a 4runner with the tire pressure monitoring system, when you upgraded from the stock 265 65R 17's did you have any problems with the Tire pressure monitoring system not registering the correct pressures due to the larger tire size?
Thanks
Paul C
09-18-2007, 04:45 PM
Re: Larger sized tires and Toyota Tire monitoring system
Thanks
Paul C
Paul
I upsized mine to 265/70R17 with no problems. You will however be driving 2 miles an hour faster on the speedo.
MSG Briz
Briz65: Black 2005 SR5 V6
17" alloys
Mods: Eclipse AVN 5435 Nav unit, Sirius Tuner, Auto-dimming mirror/w Compass,Toyota all weather rubber mats, constant on 12v outlet mod, 2 extra 12v outlets,Cargo net mod .
Thank a Veteran, they will appreciate it.
POW/MIA. We Will Never Forget.
09-18-2007, 06:16 PM
I have had the warning light on since i upsied, but in all honesty i dont think it has ever really worked well.
does anyone know if there is a sensor on the spare that could be causing the warning? (could be silly, but i have checked everything else)
2006 Titanium V6 SE
265/70/17 Nitto Terra Grapplers
Kenwood DNX8120
Soundstream picasso components
Soundstream 5.1 amp
JL Audio 12W3
09-18-2007, 08:21 PM
Yes there is a sensor on the Spare. I have had my spare set it off.
MSG Briz
17" alloys
09-19-2007, 07:57 AM
Thanks,
On the Speedo, 2 mph faster, which means, if the speedo shows 70 mph, I will be doing 68?
Thanks
Paul C
09-19-2007, 06:57 PM
Thanks,
Thanks
Paul C
nope speedo reads 70mph, your doing 72mph.
17" alloys
09-20-2007, 06:25 AM
http://www.miata.net/garage/tirecalc.html
I have been using this site for years to figure out tire sizes and how much the speedo is off.
Briz is correct.
04 4x2 Black SR5 V-6, Bilstein 5100s @ .85 w/ Moog 81088 springs 2.75" lift front, FJ Rear Springs, 265/70s, Scion T1807 HU w/ AUX input cable. 151K miles. 07/08/14 Traded-in.
08 4x4 Salsa Red SE V-6 Daystar 2.5/1.5", 265/70 Revo 2s, SpiderTrax. Traded-in on 09/14/11 W/55k miles for 08 Sequoia 5.7L
09-20-2007, 09:03 AM
Thanks for the clarifications.
Paul
HTML code is Off
