Old 01-26-2023, 08:02 AM #1
SendInTheCavalry SendInTheCavalry is offline
SendInTheCavalry is on a distinguished road
Question for Dobinson Gurus. MRR for +1” lift.
Recently I’ve experienced the dreaded Bilstein spring break on my 2018 Pro at 40k miles.
I am currently doing some speedy research trying to figure out a plan B.
One option I am thinking is a MRR setup. I plan to keep it OEM Pro height, which is +1 over other models, in the front only.
I am not interested in a 3” lift (fairly common with higher end coil overs). I want to stay stock”ish. I would like to level the truck front to rear for sure. If I gain .5-.8” I wound not be upset.
This brings me to Dobinson MRR. Here is the “build” I came up with. Can someone that knows Dobinson stuff confirm this is the build I need to retain the pro height and level the front (I am guessing that means +1 over the already +1 of the pro, effectively +2?)
SendInTheCavalry is offline   Reply With QuoteReply With Quote
Old 01-27-2023, 12:30 AM #2
MAST4R's Avatar
MAST4R MAST4R is offline
MAST4R's Avatar
I don't know if Mike is still around but he was quite helpful a few years ago. I am not sure what his current relationship to Dobinsons is. I think he had a website called Exit Offroad.
(6112s/650lb at 2.25" lift, 8100 rear with Bilstein B12 1.5" springs, Mickey Thompson ATZ P3 LTE 265 70 17, RCI set of front 3/16 skids, Shrockworks step sliders and 3/16 steel gas tank skid, C4Fab rear diff skid, Rockmen rear LCAs, Total Chaos rear LCA bracket skids, Diode Dynamics SS3 white fog lights).
Old 01-30-2023, 02:03 PM #3
quicksandTRDPRO's Avatar
quicksandTRDPRO quicksandTRDPRO is offline
Real Name: Trent
quicksandTRDPRO is on a distinguished road
Real Name: Trent
I had my OEM spring break too, and went with the Dobinson IMS setup. Love it! Went with the c59-300 spring up front (1.75" to 2.0") and c59-599 coil in the rear (1-1.25") which gave me a level look. I think if you did the c59-505 in the rear you would be a little high in the back, if you're wanting a level look? Great setup though, on and off-road. I did go through Mike, at ExitOffroad.com He was great to work with and very knowledgeable.
https://www.toyota-4runner.org/3753158-post3136.html
2016 Quicksand TRD PRO
quicksandTRDPRO is offline   Reply With QuoteReply With Quote
dobinson , front , level , mrr , pro
HTML code is Off
Dobinson lift on their 4th Gen? ryankmasuda 4th Gen T4Rs 1 05-10-2018 01:03 PM
4th Gen OME/Dobinson's lift vonguido Want to Buy/Trade 3 04-17-2018 02:27 PM
Lift and Tire gurus come on in.. mizak82 4th Gen T4Rs 4 05-09-2017 02:40 AM
Question for all you audio gurus drei4runner29 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 02-08-2017 08:11 PM
Question for the engine gurus Bama_Runner 3rd gen T4Rs 7 02-11-2014 12:12 PM
