Old 11-09-2022, 03:43 PM #1
Will_4R's Avatar
Will_4R Will_4R is offline
Will_4R is on a distinguished road
Will_4R's Avatar
Falken Wild Peak AT3W in Load Range C
I have run several sets of these Wild Peaks on one of my 4Runner's and work Tacoma (all P-series) and really like them. I would now like to put a set on my other 4Runner, which sees more 4x4/trail time so I would like to go with 285/70/17 in a Load Range C. These would replace the same sized Ridge Grapplers I have on there now (which were awesome but suck in snow which I see a lot more of now).
Oddly the Wild Peaks in C weight 5 lbs more than the E series - which puts them at 9 lbs heavier than my current Nittos. I asked Falken about that and here is the response I received:
Thank you for reaching out to us regarding the weight differences between the two tire sizes. The C load version is actually a OEM/OE tire that comes on new Jeep Wranglers and Gladiators. As such, it is spec'd to Jeep's standards and does weigh more than our E load version, despite not handling more load. While there isn't an additional ply on the C load version, there is more material built into the tire to handle the criteria set forth by Jeep.
The E load version does weigh lighter but does handle more load than the C load version. Again, that additional weight on the C load is additional material.
Other than being quite heavy, it sounds like a more rugged tire better suited to sharp rocky trails without the added stiffness of an E-series. The added un-sprung weight concerns me, the 'runner is sluggish enough with oversized tires, especially when towing (which I do a lot of). What I am curious about is if others have run this model/size/load range and notice any real difference handling with the added weight - or other comments. I also wanted to provide a first hand explanation of why the lower load range tire is heavier, since I couldn't find anything searching.
2003, Sport, V6, 4WD
Overland Warehouse/Radflo 2.0 suspension, SPC upper control arms
2016 Trail Edition w/KDSS
Icon Stage 2 suspension, BFG T/A KO2 285/70/17, C4Fab sliders
Will_4R is offline   Reply With QuoteReply With Quote
Old 12-17-2023, 02:50 AM #2
TRD PANTHER's Avatar
TRD PANTHER TRD PANTHER is offline
Real Name: BLACK TRD PRO
TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of TRD PANTHER has much to be proud of
I found your thread this evening and I’m in the same situation. You have asked all the questions and even received an answer from Falken. I’m currently running a 285/70-17 AT3W in a SL rating and have been pleased with it on and off road, but the tread wear is not great. Besides having aftermarket suspension, I have full steel skids including a rear diff skid, a lo-pro front steel bumper, 4 wide steel LFD roof cross bars, and steel sliders. I ran a KO2 in an E load prior to my Falkens, but the ride was a little rough and was getting 1mpg less. One online vendor stated 54.9 lbs.
I think your thread would have received more replies if it was in the regular 5th gen forum. What did you eventually go with?
TRD PANTHER is offline   Reply With QuoteReply With Quote
Old 12-20-2023, 07:45 PM #3
Will_4R's Avatar
Will_4R's Avatar
I went with that size in the C. It's hard to notice much if any difference from the added weight. I have about 10k miles on them and happy so far. Handle as well all other Wildpeaks I've had.
Old 12-21-2023, 08:25 AM #4
Thanks for your response to an old thread. I just started a new thread about the new AT4W’s coming in January in the forum. I will see what the new C load tire weight is then. You were correct about the current C load made for Jeeps after speaking with Falken CS. My SL’s are wearing fast, and down to 5/32 in 23k. They said to contact them when I’m at 4/32 to see what they can do in prorating my tires. Thanks again. Nice rig.
load , range , tire , version , weight
HTML code is Off
BFG KO2 or Falken Wild Peak AT3W akalito 5th gen T4Rs 106 11-27-2023 02:58 PM
Falken Wild Peak Who runs these??? Brayt4r10 5th gen T4Rs 8 02-01-2016 05:14 PM
Falken Rocky Mountain and Wild Peak Tires FTL white_n_slow 3rd gen T4Rs 6 03-01-2015 11:53 PM
Falken Rocky Mountain/Wild Peak ATS OHP 4th Gen T4Rs 18 01-22-2014 06:08 PM
Falken Wild Peak A/T Paulie6909 4th Gen T4Rs 11 10-30-2011 12:49 PM
