Old 01-05-2023, 04:22 PM #1
str8flexed's Avatar
str8flexed str8flexed is offline
str8flexed is on a distinguished road
str8flexed's Avatar
1998 3rd Gen Flywheel Wear - how bad is this?
Unfortunately, the Victory Lap starter contacts/plunger kit that was well recommended came with a plunger that was shorter than the original. After cranking, it would usually grind momentarily before starting. It's been in for a few years (not daily driven) with maybe 100 starts.
I finally figured out maybe that was the issue, pulled out the starter, and put back in the old plunger. It doesn't grind anymore. Still takes 0.5-1.5s to crank before starting.
Anyway, please see the wear on the teeth. How bad is this? Still starts fine, so I don't think I'll do anything about it. Seems like a costly replacement or complicated to DIY.
1998 3rd Gen Flywheel Wear - how bad is this?-unnamed-jpg  1998 3rd Gen Flywheel Wear - how bad is this?-unnamed-1-jpg
2017 TRD Off-Road Premium: Dobinsons lift, Icon UCA, Gobi Stealth, Cooper AT3 XLT 295/70r17, Race Relations Wheels -12 offset 8.5”, CBI front bumper, Xenon HID headlights, RCI skids, RSG sliders, Focal 690TOY front speakers, Kicker DS rears
str8flexed is offline   Reply With QuoteReply With Quote
Old 01-05-2023, 09:38 PM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Not a problem. Keep on "truckin'".
2003 Limited, V8, AWD. 4600 Bils/FJ springs, 1/2" spacer, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around.
Old 01-06-2023, 06:19 AM #3
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
Don't worry about it unless it starts grinding again, then it would be time to replace the flywheel.
2004 Limited V8
Old 01-11-2023, 04:02 PM #4
Keros Keros is offline
Keros has a spectacular aura about Keros has a spectacular aura about
If you wanted to be sure, you could probably paint the faces of a group of teeth, and engage the starter across them. I'm certain the hassle would be getting that group lined back into the window to inspect.
If the tooth contact has removed the entire paint across the flywheel's teeth, the engagement should be great. If it's doing weird stuff, well, you'll know and can decide from there based on how much paint is left on the teeth.
The same method is used to a ring and pinion, I'm sure it would work great here as well.
2005 V8 Limited
Bilstein 6112/5160, ADDCO bars. 18x9 Beast with 285/60R18 BFGs
IPT valve body, DT shorty headers, Dirty Deeds BAMF exhaust
Keros is offline   Reply With QuoteReply With Quote
bad , grind , plunger , starter , starts
HTML code is Off
known flywheel issues 01thunder 3rd gen T4Rs 5 08-04-2017 08:59 AM
Clutch Kit and Flywheel Happy Nappie New Members 1 07-17-2014 10:35 PM
New flywheel problems wilkymouse113 Problems & Warranty Issues 1 07-24-2011 04:47 PM
Flywheel resurfacing Forumboarder12 3rd gen T4Rs 0 12-01-2010 07:16 PM
