Old 04-28-2023, 01:12 PM #1
janimal janimal is offline
janimal is on a distinguished road
How's my alignment? Mildly rough drive handling on highways
For context, I installed a new suspension a few weeks ago with some new tires. Bisltein 5100 all around with OEM front springs and Bisltein rear springs, and 285 Wildpeak AT3W. It's now sitting at a 3.25" lift front and 2.5" rear. I also got a shop installed a pair of JBA upper arms due to the 3" lift.
Anyways, I drove the runner for few days and noticed some pulling to the right. So I got an alignment done to fix the issue. Two (2) things I noticed:
1. Steering wheel is slightly off-centered, probably 1 or 2 degrees to the right. It seems like it's driving straight now, maybe just drifts to right more vs a pull. But when I try to straighten the steering wheel it would then drift to the left.
2. Going over 65mph on highways the handling becomes less stable. The steering wheel feels a bit drifty. Meaning I have to concentrate on holding and controlling the steering wheel. Although it's not bad on short rides, I imagine it could become exhausting on longer drives.
I'm likely gonna go back to the alignment shop for them to make some adjustments but I just want to make sure I know my demands before going in there. So here are my questions:
  1. To straighten the steering wheel, do I just need to make a small adjustment to the tire position or would I risk messing up the toe alignment?
  2. What needs to be adjusted to make the handling better? Will it help if the caster is set to higher deg, 3-4 deg?
How's my alignment? Mildly rough drive handling on highways-img_5828-jpg  How's my alignment? Mildly rough drive handling on highways-img_5829-jpg
22 4Runner SR5
janimal is offline   Reply With QuoteReply With Quote
Old 04-28-2023, 03:08 PM #2
tjnptel1 tjnptel1 is offline
tjnptel1 has a spectacular aura about tjnptel1 has a spectacular aura about
Sounds like you need a panhard correction kit.
Bolt-On Trackbar Correction Kit (BOTCK) For The 5th Gen 4Runner
tjnptel1 is offline   Reply With QuoteReply With Quote
Old 04-28-2023, 04:41 PM #3
Ah TIL about panhard/trackbar. After doing more research on this, I feel like this is what's causing the handling issue. Now I just gotta wait til the kit is back in stock.
Do I need a re-alignment after installing the kit?
22 4Runner SR5
Old 04-28-2023, 07:36 PM #4
riceandpho's Avatar
riceandpho riceandpho is offline
riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough riceandpho is a jewel in the rough
riceandpho's Avatar
i think you need to have them add more caster, also your toe looks like it pulls to the right.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
riceandpho is offline   Reply With QuoteReply With Quote
Old 04-29-2023, 06:12 PM #5
i don't believe so but riceandpho suggests you may need to do it again
alignment , handling , make , steering , wheel
HTML code is Off
Rough Shift/Lurch from Park to Drive rocky.mtn 5th gen T4Rs 21 04-28-2023 08:56 PM
rough idle when stopped but in drive..... hdoggie24 Problems & Warranty Issues 31 11-08-2021 12:14 PM
Billstein 5100's & 1" springs. Much floatier handling normal? *Alignment sheet edit* Quiero 4th Gen T4Rs 10 05-28-2020 03:48 PM
5th gen handling. Tire pressure vs alignment. surfnturfer 5th gen T4Rs 14 06-19-2014 07:39 PM
Best Tires for Michigan Highways lyle 3rd gen T4Rs 7 10-05-2006 10:58 PM
