Old 04-28-2024, 01:41 PM #1
GAsr5 GAsr5 is offline
GAsr5 has a little shameless behaviour in the past
AudioControl LOC hiss
Stumped and frustrated
So I finally replaced a shitty 5 channel amp and eq. I had a taco tunes 5 channel amp and Recurve EQ. For reference I have a 2017 4Runner with image dynamics component set.
When I got this installed about 5 years ago I immediately had the following issues;
- static pop noise when turning car on
- ground noise out of right tweeter (would get louder when reving)
- bass non functional
I finally took it back in to another shop to get everything clear up. I had my doors deadened, installed pioneer GM-DX975 and Audio control lc7i pro.
Everything is great except I am still having ground noise. When I have the radio of you can hear a slight buzz/hiss still.
The shop said this is typical as the speakers aren’t receiving a signal. I found this hard to believe but I wasn’t quite sure what to say as this is not my expertise. I thought it was a ground issue or maybe a gain but the installer didn’t agree.
I’m happy with everything except this. The component set REALLY came alive with this new amp and it sounds great but want to get this last piece fixed. Any suggestions? I’m new to car audio as well.
Thanks
GAsr5 is offline   Reply With QuoteReply With Quote
Old 05-01-2024, 09:39 PM #2
Bump. Feedback welcome
Old 05-26-2024, 09:17 PM #3
weberlukas74 weberlukas74 is offline
Real Name: Lukas Weber
weberlukas74 is on a distinguished road
Bad grounding can indeed cause noise. But, I’d suggest checking if the AccuBASS and other features are correctly set, and that the input gain isn't too high.
Also, low-quality or damaged RCA cables can cause noise.
Make sure the wires between your head unit and amp are good. Look for any bends or cuts in the wires or anything that might mess with the signal.
If you hear a high-pitched hissing sound, it might be from your car's alternator. That's a common problem in car audio, but you can fix it by adding a special filter for that noise.
You could try ground loop isolators if nothing else works, though they might affect sound quality.
weberlukas74 is offline   Reply With QuoteReply With Quote
Old 09-11-2024, 04:05 PM #4
sara45 sara45 is offline
sara45 is on a distinguished road
Post It sounds like you’ve made some great upgrades! For the ground noise issue, it might
Thanks
It sounds like you’ve made some great upgrades! For the ground noise issue, it might be worth checking out yeloos.com for tips on isolating ground loops or improving your grounding setup. Sometimes a simple fix or adjustment can make a big difference. Good luck!
sara45 is offline   Reply With QuoteReply With Quote
amp , audio , car , ground , noise
HTML code is Off
Air conditioning hiss texadelphia 3rd gen T4Rs 1 09-11-2020 07:47 PM
AudioControl Lci6 w/Entune Jeff614 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 09-01-2016 01:29 AM
Installed KENWOOD eXcelon KDC-X492/Audiocontrol Epic 150 rollingthunder Engines / Suspension / Wheels / Tires / Audio / Accessories 3 02-15-2009 05:35 PM
Has anyone used a AudioControl EPIC-160 20054runnerfan Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-19-2005 09:28 PM
new hu+amp in 4th gen now hiss whine mud Engines / Suspension / Wheels / Tires / Audio / Accessories 13 02-17-2005 07:52 PM
