Old 09-15-2024, 06:58 PM #1
BackRoadsAreBetter BackRoadsAreBetter is offline
BackRoadsAreBetter is on a distinguished road
Rear alignment
I have a 2013 that has an issue with the alignment in the rear.
Pretty sure a railroad crossing bent the housing or hub flange but I want to figure out how to go about finding what the issue is before just throwing another housing at it.
The toe is out on both sides, as if the rear axle is at a slight angle, but is out a bit more on one side. So slightly psoitive on one side and negative on the other.
Any advise is welcome.
I can post a photo of the last alignment readout if it helps
BackRoadsAreBetter is offline   Reply With QuoteReply With Quote
Old 09-15-2024, 07:29 PM #2
Zhehan Zhehan is offline
Zhehan has a spectacular aura about Zhehan has a spectacular aura about Zhehan has a spectacular aura about
I would check the rear control arm bushings and also look at the arms themselves to make sure they are straight and not bent.
My .02
2000 4Runner SR5 Manual Trans Federal Emissions - Eibach Pro-Truck coilovers, LC 7.5/Tokico Black, JBA UCA, SPC 25945 RLLs, Mevotech Supreme RULs, TrakMotive Xtended Travel CV Axles TO-8043ET, South Bend Rally Clutch, ES & Whiteline Bushings, MagnaFlow Cat-Back, Deck-Plate Mod, 4.56 Yukon Gears, Yukon Grizzly Rear Locker, Bushwacker Flares, 16x8 Wheels w/ 285/75 General Grabber AT2, 229K+ Miles
Zhehan is offline   Reply With QuoteReply With Quote
Old 09-16-2024, 12:25 PM #3
Thanks for the input.
Do the control arm need to be removed or can they be inspected on the vehicle?
alignment , housing , issue , rear , side
HTML code is Off
Rear wheel out of alignment Haydenatx 5th gen T4Rs 19 07-13-2020 04:46 AM
Problem with rear alignment ThShowzOver 4th Gen T4Rs 3 05-22-2019 12:37 PM
4th gen Rear Alignment Problems ThShowzOver 4th Gen T4Rs 8 02-02-2018 06:53 PM
Rear Window Alignment Red Wagon Classic T4Rs 1 10-03-2008 06:34 PM
Rear Wheel Alignment <<<< 4th Gen T4Rs 2 01-23-2006 09:27 PM
