Old 10-27-2024, 05:07 PM #1
matthewkristof's Avatar
matthewkristof matthewkristof is offline
matthewkristof is on a distinguished road
Second Camera using RCA Switcher
I installed the Sony XAV-AX6000 last year to replace my aging stock radio. It has been excellent but unfortunately, only has one camera input. I've been using the backup camera but recently wired up a forward camera and purchased an inexpensive RCA switcher. It uses a slide switch to toggle between input 1 and 2.
I've gotten it working but want to wire it up to a toggle switch so I can hide this unit in the dash. I cannot figure out how to do this. I looked up some wiring diagrams online for slide switches but most are for 3 or 6 pins, while I have 12 pins. I know there's pins there for the audio connections but I'm just interested in the video ones. The dots in the diagram are the video lines traced to the slide switch. I've tried tracking the connections to the soldering on the circuit board but haven't been able to get it to work.
Hoping someone smarter than me can help me out. Appreciate any help!
Second Camera using RCA Switcher-img_2870-jpg  Second Camera using RCA Switcher-img_2869-jpg
2007 SE, Galactic Grey Mica - original owner
matthewkristof is offline   Reply With QuoteReply With Quote
Old 11-05-2024, 11:23 PM #2
A/V1's Avatar
A/V1 A/V1 is offline
Real Name: Brad
A/V1 is on a distinguished road
A/V1's Avatar
Real Name: Brad
Lightbulb
How's it going?
Your switcher is definitely not a great choice for the car. Your cameras don't have audio, so you will only be using the yellow RCAs.
A simple dual Bosch style relay setup will take care of your switching.
I added a picture & hope it helps. The 12v in can be controlled by pretty much anything.
Second Camera using RCA Switcher-2-cameras-into-one-jpg
Vehicle: Black 2003 T4R Limited V8 4WD Mods & Equipment: Hail Damage; Kenwood DDX573BH/ rear camera; GX470 Overhead; DC power, A/V aux jacks, & USB plug inside center console box; DAC switch relocate; Interior LED swap; Footwell LED lighting; Muth heated signal mirrors, LED tails, & Valor exhaust tip.
Support our troops!
A/V1 is offline   Reply With QuoteReply With Quote
Old 11-06-2024, 02:32 PM #3
Yea, it's not the best option for sure. The headhunt itself doesn't have the option for a second camera or video input, so I was trying to create my own. I managed to add the anytime backup camera employing a simple rocker switch which I use surprisingly much.
Thank you for your diagram. I got the main gist of it. I'm guessing the two lines coming out of the nav radio and two cameras are positive and negative leads, right? Also, do I control the front/reverse camera through the 12V input?
camera , pins , slide , switch , switcher
HTML code is Off
Any way to reverse camera view on Pioneer ND-BC8 back up camera and AVH-2550NEX? cwilliams563 4th Gen T4Rs 0 06-11-2020 09:53 PM
Anytime Backup Camera and Front Camera - February 2017 Group Buy bjohnston115 Group Buys 101 05-06-2020 11:39 AM
Anytime Camera w/Multi Input Switcher matthewkristof 4th Gen T4Rs 0 07-28-2014 07:01 PM
Navigation Video Switcher System CuzzinOlaf Engines / Suspension / Wheels / Tires / Audio / Accessories 7 02-15-2006 10:42 PM
