Old 03-22-2025, 09:43 PM #1
Geology's Avatar
Geology Geology is offline
Geology is on a distinguished road
Geology's Avatar
Twice aligned, still have outside tire wear?
Got some Nitto Ridge Grapplers and loved them for a year, then noticed bad sway bar bushings (frame/inside were loose due to rusted brackets) and bad LBJs. Fixed issues with larger than stock bushings and had a shop do new LBJs but noticed bad outside tire wear up front on both sides.
I'd love anyone's advice on what to do mechanically if anything to stop the outside edge wear since the wear seems to have continued after the fixes and even after two alignments. pics below of spec sheets of most recent two by same shop that did LBJs. I've rotated well enough that I'm thinking about having the tires flipped around since they all have outer edge wear.
Pertinent info (maybe):
2002 SR5 @312k
OME 881/890 with ~180k/15 years on them
New LBJs but after some tire wear
Sway bars/end links fixed but after some wear
Panhard bar adjustable brackets so it's lined up right
I corner hard and drive in extreme crosswinds in Wyoming.
Pics of alignments and FL tire:
Twice aligned, still have outside tire wear?-tire-jpg  Twice aligned, still have outside tire wear?-specs6-jpg
98' SR5 4Runner 285k. (Drunk teen wrecked into it, totaled)
01' SR5 4Runner 240k. (Another dumb not at fault wreck, totaled)
02' SR5 4Runner (Current). OME 881/890, Winch + Plate Bumper, Taller ATs, Intake elbow/ISR/running boards removed, Yotatech Heads.
Geology is offline   Reply With QuoteReply With Quote
Old 03-23-2025, 08:41 AM #2
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
If I were you I would check the toe and camber myself and adjust as necessary.
Download 'Angle Pro" on your phone, or purchase 'Gem Red" level box, it's cheap, to check camber.
Check your toe at wheel center front of tire/rear of tire. I have a couple of 6x6 cut to the height of wheel center line, place one in front of each front tire then measure across from center of tread to center of tread and record. Then put the 6x6 in back of each front tire and do the same. If the difference (toe) is more than 1/16" in or out, adjust it with tie rods to 1/16", or less.
Put a straight edge vertically across your front rim and use angle finder to measure camber. I like them almost vertical, but a degree either way is fine, IMO. If you find that the top of your tires are tilted out a couple of degrees I would have camber adjusted to straighten them out, vertical to 1 degree in at the top.
I have SPC UCA, so I can adjust camber myself. I have Michelin LTX 265/65R17 with 50k miles, they have perfect tread wear. I also run my LCA in the neutral position and locked in that position with cam eliminators.
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 03-23-2025, 07:39 PM #3
Hungryhawk Hungryhawk is offline
Hungryhawk will become famous soon enough
I found the chunkier the rubber pattern the harder it is to correct wear patterns by driving.
Our solid rear axles can straighten out tire treads.
You might try running the worn front tires on back for as long as necessary. Assuming the current tires can be rotated with ok tread on front.
Hungryhawk is offline   Reply With QuoteReply With Quote
Old 03-24-2025, 08:06 AM #4
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I watched a 20 minute video on youtube yesterday that you might find interesting: "Everything you need to know about Alignments" by Overland Outfitters. I think you would find it useful, he discusses Toyota specifically.
Old Yesterday, 07:18 PM #5
Geology's Avatar
Geology's Avatar
Thanks guys, liked etc. each of your replies. I will first just rotate since the rears are still ok, a lot better actually. Airing down the rear to 29 and the front to 31 should have helped but not enough I guess.
I've done a fishing line alignment before but I'll take the advice to just use an angle meter or my phone to check things first. Issue is that I don't have a truly flat spot to do it so we'll see how it goes. The angle meter on my phone is fairly good, I use it to level out the thing when I sleep in the back for work like I've been doing recently in the field so that's a great idea.
I'll check out that YouTube vid tonight. Sorry for not checking back again sooner but I've been camping on a very remote jobsite after a client asked me to get some work done for good money suddenly.. Gold is through the roof and exploration services are in demand.
Old Today, 08:13 AM #6
rdruss's Avatar
Real Name: Ron
rdruss's Avatar
Real Name: Ron
Something I also use is a straight board about 66" long, Like a 1" x 3" x 66", and I've marked two lines 61" apart on it as that is the listed track width for my 4th gen. I use this as a quick check for toe, I can put it on the 6 x 6's I use to measure toe, put one of the marks in line with the center of one wheel and then look at the other end to see if it's on center or is off one way or the other.
bad , lbjs , shop , tire , wear
HTML code is Off
What's causing this tire wear pattern? Alignment or tire pressure? TheHolyCannoli 5th gen T4Rs 13 12-01-2020 04:10 PM
Odd Single Tire Wear - defective tire, wheel bearing, other? High_Country 5th gen T4Rs 4 02-22-2017 07:28 AM
Tire wear Bourbonator Engines / Suspension / Wheels / Tires / Audio / Accessories 8 07-26-2016 12:09 PM
Tire wear dereky 4th Gen T4Rs 6 10-13-2015 09:08 AM
Bad Tire Wear curt4x4 3rd gen T4Rs 7 03-06-2011 08:32 PM
