03-30-2004, 03:56 PM
Side exhaust mod (for back window lovers)
I was at the gas station yesterday, and found an older generation 4runner. I'm not sure if it was stock or not, but he had his exhaust tip running off to the side instead of straight back (as in the 04's). He said he can have the back window down, and have no exhuast smell slip in. Can someone verify this for me? I love that back window, and I want to be able to keep it down while driving and not die at the same time. Has anyone done this for this purpose??? Or even for any other purpose???
Black '04 SR5 4x4 V8 -
Extras: Nav, Homelink, Xenon everything, Katzkin leather, JBL 10 spkr system, 5% tint, Toyota bug shield, flowmaster exhaust
03-30-2004, 04:05 PM
Real Name: JR
Real Name: JR
i think the 3rd gen runners had exhaust out the passenger side. at least on my 98 runner it was out the side and i could leave the window fully down and get no exhaust smell.
80 PhoenixLJ/84 CelicaGT/84 & 87 Cressida/89 Toy Truck 2wd/91 Cressida x 2/93 Paseo/96 Protege/98 4Rv6/04 4R Sport v8/06 Taco AC v6/07 Sonata SE v6/09 Rav4 v6/10 Legacy 3.6R/12 Taco DC v6/09 Avenger SXT/09 Corolla XLE/14 4R LE/14 Rav4 XLE/15 Camry XSE/16 Taco DC v6 Sport/16 Highlander XLE/18 Tundra Plat/18 Santa Fe Ult
2014 4R LE Classic Silver Build Thread
E5-Exhaust Tip / MF-Mudflaps / R6-Running Boards / 2Q-All Weather Mats / 3P-Paint Protection Film
03-30-2004, 04:12 PM
Mine (2nd gen) with the rear window down by itself will because there is a backdraft pulling air in but if I put my drivers side window down even crack it it will pull the air out the back and it's fine.
NoDak is this the same with you or could you just put your rear down and not have the exhaust pull in the back?.
01 MR2,96 Vette,93 4runner
03-30-2004, 04:25 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
I had mine turned out to the side mainly because I hated the way thestock pipe was sticking straight out. I also hated that resontator bulge at the end of it. I didn't change out the muffler, I just had them cut it off behind the resonator, turn out the new pipe and put the tip on. I haven't really had a chance to ride around with the window down, but I shouldn't get any of the smell inside.
03-30-2004, 04:55 PM
Real Name: JR
Real Name: JR
my 3rd gen exhaust was a single pipe in the same location as momo's setup, about even with the bottom of his mudflap and sticking out a bit further also. also it was pointing downward toward the ground at a steeper angle, say about 15-20 degrees angle. probably easier for someone to post a pic of the 3rd exhaust than trying to explain this.
i did notice fumes when at low speeds, say around 20-25mph or lower. but at 30+ mph i couldnt tell any fume smell in the cabin.
03-30-2004, 05:20 PM
Momo,
I have to apologize for my ignorance, but what is the actual purpose of the resonator??? I took a quick glance and thought that piece was just a small muffler. Did you change out your exhaust, or just the tips?
Thanks again!
03-30-2004, 05:43 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
The resonator just helps keep the sound of the exhaust down. I was worried that when they cut it off that is was going to effect the sound, but it hardly made any difference. Just because I drive it every day I could tell, but it wasn't hardly enough to even mention. I left the stock muffler on, because I didn't want it to be any louder. It was just for the looks.
03-30-2004, 06:06 PM
Thanks for the info.
Next time you are out and about, will you give the exhaust/back window a try and let me know your results?
03-30-2004, 06:07 PM
Oh yeah... V6/V8???
03-30-2004, 06:12 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
Originally posted by swooopeno
Oh yeah... V6/V8???
V8.....
03-31-2004, 02:49 AM
how much did the exhaust co charge you for your entire mod?
4Runner.AaronRosales.com
Shop.AaronRosales.com
2003 TiTaniuM 4Runner 4.0L V6
5% Tint all around
K&N FIPK
6.5" LCD TV
PCX-1250 Mono 500w amp
JLAudio 12" W3v2
xTec Hid 5000K Conversion
P265/65R/17 Bridgestone Revo A/T
03-31-2004, 12:41 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
For cutting the pipe, then fitting the piece to turn it out and the tip, it was about $65....To me it was well worth it.
03-31-2004, 12:49 PM
did it fix the sulfur smell in the cab?
5% Tint all around
K&N FIPK
6.5" LCD TV
JLAudio 12" W3v2
03-31-2004, 12:53 PM
Registered User
Real Name: Morris
Registered User
Real Name: Morris
I didn't ever leave the house yesterday so I never really got a chance to try it out. I am about to leave here in just a second to run some errands, so I will let you know when I get back.
03-31-2004, 01:05 PM
hey Momo
do you have a 2wd or 4wd?
Victor
08 FJ TT
94 FZJ80
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
HTML code is Off
