Originally posted by ptung07
The cable replacement includes:
The new grounding point that connects to the body of the car then connects to the battery. Then the cable connects from the battery (-) to some where else in the car where it is supposed to. (You can tell I have no clue what to do right now haha)
(car body) -------cable black----> [battery negative point]----cable black--->(some point in the car)
You definitely should repair this break in the wire. The best way to do that is buy the replacement (either from the auto parts store or the dealer; I would price them both.) Do it yourself and save some of your money, you don't need to pay the stealer the installation labor.
It's not as intimidating as you think. You already have 2 connections you can see and handle. The end you can't see goes to the starter. Here is the sequence I would do after buying the new cable:
Disconnect the current cable at the neg (-) just like you did above.
Disconnect it at the fender.
Trace the cable down to the starter and disconnect.
Connect the new cable at the starter.
Connect at the fender.
Connect to the battery last.
Pride in working on the T4R: priceless!
Another way to fix would be to splice a new length from the fender to the battery. Look at the connections. See if you feel comfortable and have the tools to pry these open, insert a new short length (from an auto store) and close these crimps...
Thought so. Go back and look at the first plan again.
'04 SR5 V6 4x4 Galactic Grey Mica. Delivered 03/17/2004. Link to my mod list in posts 7, 8 & 9 of this thread:
http://www.toyota-4runner.org/showthread.php?t=21354
____________
[__/[_[_\____\,_
L---L-L-L--0=*=0
`(o)_---(o)_--)_)`.........
The battle begins at the end of your driveway... Game On! "Car!"
