08-28-2008, 02:18 PM
#16
Originally posted by irish44j
did you splice the antenna amp power into a live power wire? From what I read, you need power to the antenna amp for it to actually be doing anything.
how is your AM reception? All the best sports stations in this area are AM.....
I didn't do any splicing, or anything with amplifiers. The antenna cables plug right in to the Scion head unit. Just bend and remove the little metal cover over the second hole. The back of the head unit is layed out much like the standard 4Runner head unit.
My AM reception is just fine.
4Runners have their antennas in the rear-side windows. The original head unit uses both antennas (differential antenna). The Scion head unit only uses the primary antenna. Reception is slightly restricted, and orientation dependent.
Brian
http://i125.photobucket.com/albums/p...8E1457slim.jpg
2004 Sport V6, Build Thread, OME, SpiderTrax, Goodyear 275/70R17, Super Sliders, Scion radio, CB,.......
12-11-2008, 12:37 PM
#17
Functions
I finally installed my T1806 with ipod control. A couple questions. How do you customize the lettering on the unit? When searching through artists is there a way to scroll faster (A,B,C) as opposed to sequentially through the list? It takes forever to get to U2. Is there a manual for the T1806? Thanks in advance
2004 SR5 V6
Michelin LTX M/S 265/70 SR17
Huskyliners front, rear and cargo
Thule Ascent 1700
Other modes of transport:
Montrail Torre GTX Hiking Boots
Jamis Dakar XLT 1.0 MTB
Bombardier 16ft Sailboat
Rossignol Bandit II Downhill Skis
Rossignol EVO XC Skis
Atlas 825 Snow Shoes
12-11-2008, 01:30 PM
#18
Re: Functions
Sorry for the delay in answering.
There is a manual. I printed mine from somewhere online. I can't seem to track it down at the moment.
The lettering is a little difficult. I had to use the manual to figure it out. If you disconnect your battery, it will revert back to the default "Scion" letters.
I have not found a way to get through the lists any faster than what you have. It is a pain. So far, that is the only thing I don't like about these radios. I am going to pose this same question on a Scion forum, and see what the kids can tell me about it.
Brian
12-12-2008, 07:11 PM
#19
Just a quick question:
Do any of these units plug and play on a 2004 SR5? Just curious about the 1809. I don't have the JBL, just the base head unit. I'm looking for a good, OEM quality fit and finish for my new head unit and stumbled across this post.
Any info is appreciated, thanks.
2004 SR5 V8 4WD Natural White
Retrofitted tails to Toyota factory LED
Tint 35% Fronts/20% Rears
Chromed Signal Bulbs
PIAA Headlamp Bulbs
LED Plate Bulbs
Valor Exhaust Tip
Dbl Decker Cargo
Pwr Moon Roof
Garmin GPS
Rear Spoiler
265/65R17
12-12-2008, 07:32 PM
#20
Note my mods. The Scion is plug & play for all non-JBL equipped 4th gens.
2004 SR5 V8 - Natural White
265/70-17 Nitto Terra Grapplers / Hanna Quality Sliders / Scion Xb Radio w/ XM / SAW Coilovers (F) / OME 895 & N141 (R) / Light Racing UCA / Kurtfab Diff Bracket / Toyota Skid Plate / 06 LED Tails / Hard Wired Nuvi 760
12-12-2008, 07:45 PM
#21
Right on man, I guess for clarification's sake, is that to include all of the Scion H/U's? I might be able to get an 1809 for a reasonable price from a friend and so that's why I ask. I'm not sure if it will fit the unmodified stock trim though, if it's got the same dimensions as yours, it should.
Thank you.
PIAA Headlamp Bulbs
LED Plate Bulbs
Valor Exhaust Tip
Dbl Decker Cargo
Pwr Moon Roof
Garmin GPS
Rear Spoiler
265/65R17
12-17-2008, 07:10 PM
#22
There is a guy on DiyMobileAudio.com that installed the T1809 in his 4Runner. He really likes it.
You retain the steering wheel controls, and you can control an iPod too. XM & Serius ready. RCA outputs for external amps.
Brian
12-24-2008, 01:42 PM
#23
Does anyone know if a Scion unit will work with a JBL equipped 4runner?
01-08-2009, 06:36 PM
#24
It will work; but you need to purchase an extra adapter kit. Other than the iPod connections (also an extra cable purchase) I don't see any advantage of the Scion radio, over the JBL.
You can also get an iPod adapter for your JBL radio.
Brian
01-09-2009, 01:24 PM
#25
T1808 Cable
Is there a Scion part number for the Ipod cable? The aftermarket one is rather expensive. Also do you still have an AUX port on the T1808?
-chunkee
01-09-2009, 02:32 PM
#26
Re: T1808 Cable
-chunkee
I have not seen an AUX port in the T1808. When it is mounted in a Scion, I think there is an external AUX port, that is wired in, with the iPod cable; but I am not sure about this.
The Scion cable parts are much more expensive than the eBay part. In the Scion cars, there are two separate cables, leading from the console (where the iPod connects), to the wiring harness in the dash. Then there is a cable, wrapped into the dash harness, the leads to the radio. This cable can not be ordered from Toyota. To acquire this cable, a Scion owner would need to cut the wrapps off the wiring harness in the dash, and thread it out of the dash. The other two cables are easy to remove, and can be ordered from Toyota.
Since you can get a Scion head unit so cheap, the total cost of the head unit and the eBay cable is still not expensive.
On other forums, folks are suggesting that there are better sounding, aftermarket stereos, for the same money; and they include the necessary iPod cable. Although you usually have to purchase an installation kit or two. BUT, they certainly do not look like a factory radio.
Brian
Reason: Spelling
01-09-2009, 02:37 PM
#27
The T1808 headunit has the ipod interface connector along with a steering wheel audio control/AUX in connector.
Yes, both can be connected at the same time, and swiitched between by using the AUX button on the front of the headunit.
01-09-2009, 02:52 PM
#28
On the back of the head unit, there are a number of plugs. One is the power and speakers. One is the steering wheel controls. One is the CD changer, and one is the iPod.
I use the term "CD Changer", because that is the way the 4Runner is set up. I don't know if the Scion has an external CD changer option. Maybe they just wire that connerctor to an external AUX port, and allow you to switch between the iPod and that "CD Changer" port.
I have a USA Spec TOY-15 box, purchased for my original head unit, that plugs into the "CD Changer" port. It allowed either iPod or AUX connections. I suppose it could be plugged into the T1808, in the same location, and used as an AUX port.
I wonder if the AUX switch on the front of the Scion radio, switches between the iPod port and the CD Changer port.
Brian
02-11-2009, 11:43 AM
#29
Question...
For close to the same amount of money which would be a better option for adding iPod/iPhone controls:
1) Keep factory radio and add a USASpec adapter
2) Install a Scion 1806 or 1808 (I want knobs) head unit instead.
Sorry aftermarket head units our out of the question, I'm never crazy how they look with trim kits which is why I don't think I'm going to go with a nav unit either.
If a Scion is the way to go, I may even splurge and get the 1809.
Jay
02-11-2009, 03:22 PM
#30
I have used both systems, and the Scion unit with iPod cable definitely works better than using a USA SPEC adapter and the original 4Runner stereo.
The USA SPEC system lost a lot of voice sound and volume. Music never sounded correct. If I adjusted the setting for the iPod, it sounded horrible when I went back to FM. The volume also had to be very high for the iPod; so I had to remember to turn it back down, before switching to FM.
Scion and cable works properly, and sound quality is very good.
If you don't like the way aftermarket stereos look, you may not want the most recent models of Scion radio either. They are marketed to the same buyers, and they are starting to havethe same flashy light, colors and looks.
I'm with you on the use of knobs over buttons. That is why I picked my T1806. The T1808 is the same, but the T1809 is more like the kid radios (bling).
Brian
HTML code is Off
